Setting the Dwell on Points
Old Aug 16, 2013 | 12:11 PM
garyfoust's Avatar
Help! It has been a while since I put points in. The car is a 67 Olds 442 and gapped the points at .016 but my question do I set the the dwell at 30 with the vacumn advance on or off. I know the timing is at 7 1/2 with vacumn advance off but can't remember if dwell is set with advance on or off?
Old Aug 16, 2013 | 12:42 PM
65B01Delta's Avatar
Gary, I never taken the vacumn advance line off when I set my points. Just my 2 cents. Also saw your car sitting out today, moving right along.
Old Aug 16, 2013 | 01:18 PM
The vac advance has no effect on dwell, only on initial timing, so it doesn't matter one way or the other.
Old Aug 16, 2013 | 01:47 PM
It needs to be set to 30, no more no less. After you set your dwell you need to go back and reset your timing. And as others have said the vacuum hose will not effect dwell.
69442murph
Nov 12, 2011 08:45 PM
ChefDeadpool
Dec 14, 2010 01:08 PM
Prsabordo
Mar 3, 2010 02:38 PM
Pfiffle
Mar 16, 2008 10:10 PM
dynamic88builder
Nov 25, 2005 08:31 PM
