Tune up and dwell
Old Dec 10, 2010 | 02:44 PM
ChefDeadpool's Avatar
Tune up and dwell
So when I replaced the points in my Cutlass a few months ago, the manual insisted I check the point dwell. So I went out and bought a combo Dwell/Volt/Tach meter (it's all that was available) and hooked it up. The dwell read exactly within spec after disconnecting/capping the distributor vacuum advance line, which I found suspicious. Should I need to adjust the dwell?
Old Dec 10, 2010 | 03:01 PM
InfoJunkie's Avatar
InfoJunkie
The dwell must be adjusted only if it is not within specs. Someone last week I think did a lengthy explanation of what the dwell is and how it works. Next time you do the points get a Pertronix unit and eliminate the points.
Old Dec 14, 2010 | 10:05 AM
BILL DEMMER's Avatar
Just the facts...
or switch to the h.e.i. system
bill
Old Dec 14, 2010 | 11:35 AM
captjim's Avatar
Dwell is constant, it should be 28-32 degrees. The ignition TIMING should change (if it is hooked up to manifold vacuum), not the dwell.
Old Dec 14, 2010 | 01:08 PM
Oldsguy's Avatar
Past Administrator
Dwell is the number of degrees of distributor rotation that the points are closed. The dwell is directly related to:
1) How close the point gap is set (variable)
2) The lobes on the distributor shaft which open and close the points (not variable)
So you set your dwell by setting your point gap.
RXN
May 13, 2013 06:45 PM
69442murph
Nov 12, 2011 08:45 PM
Prsabordo
Mar 3, 2010 02:38 PM
Pfiffle
Mar 16, 2008 10:10 PM
dynamic88builder
Nov 25, 2005 08:31 PM
