Fuse Panel Bolt
Old Nov 2, 2013 | 06:57 AM
Mr Nick's Avatar
Fuse Panel Bolt
Lost the bolt that holds the fuse block together. Does anybody know the specs off the top of their head, so I can replace it?
Old Nov 2, 2013 | 08:05 AM
Octania's Avatar
how about another OEM bolt?
I must have dozens on hand, if I can find one...
year and model would be nice to know.
I am guessing '69 Cutlass, but need to be sure.
Old Nov 3, 2013 | 06:04 AM
Mr Nick's Avatar
An OEM bolt would be great, Chris! Yes, 1969 Cutlass.
Old Nov 3, 2013 | 08:05 AM
billmerbach's Avatar
major noob
I'm assuming based on the one of of my dads van they should be about a 7 mm maybe its different on the olds
Old Nov 4, 2013 | 07:57 PM
junior supercar's Avatar
Nick, pretty sure I have an OEM one too, if Chris (octania) can't help you out.
Old Nov 4, 2013 | 08:01 PM
Should be an easy replacement - just head out to the boneyard and pick on a wreck
Old Nov 4, 2013 | 08:17 PM
Mr Nick's Avatar
Thanks I'll let you know.
Unfortunately, the boneyards near me are now landscaping and concrete companies.
Old Nov 5, 2013 | 05:35 AM
69442C's Avatar
Here's a photo of the original bolt with the specs. There is a 1/8" space between the (2) 5/8" sections I show and that 1/8" space has a groove on the bolt to accept an "E" clip which retains the bolt to the connector. I'm sure if you go to your local hardware store and get a 1/4-20 bolt like this one and even 1-1/2" length would work fine. Or to duplicate the original length, get a 1-1/2" length bolt and cut it down by 1/8".
I'll offer the one I have but I'm sure it will be much cheaper for you to get a bolt locally at a store.
Brian
Old Nov 5, 2013 | 08:23 PM
Mr Nick's Avatar
BOOM! Thanks a ton, off to Lowe's I go this weekend.
Oldscutty72
Dec 28, 2015 01:56 PM
65droptop442
Apr 26, 2013 06:25 AM
jpc647
Oct 2, 2012 11:33 AM
White_Knuckles
Aug 23, 2012 09:08 PM
wantacutlass
Jun 17, 2010 04:09 PM
