1969 hurst olds survivor
Old Jun 23, 2013 | 08:56 PM
springbryan's Avatar
RelaxinOldsGuy
I have come up with a 69 Hurst Olds survivor. It needs a water pump, a master cylinder rebuild and an alternator belt. The advice I was given by a local mechanic was to have the water pump rebuilt. I am looking for suggestions on where to have this done. I would also like to ensure I get back MY original part. Suggestions?
What parts should I use to rebuild the master cylinder to keep it original. Where would you recommend I get the parts?
Any insight on the original brand and part number for the alternator belt?
Thanks!!
Old Jun 24, 2013 | 05:19 AM
tru-blue 442's Avatar
Old School Olds
If it were me, I would get what I needed at
the parts house and pay the core charge, keep
the originals for a rebuild at a later date.
I can't help with the belt part #.
Good luck and post some pics when you get a chance.
Sound like a very cool find.
Old Jun 24, 2013 | 09:02 AM
Hairy Olds's Avatar
Shoveling Snow
For the water pump I have used Arthur Gould to rebuild my original pump on my 67. They rebuilt mine in 2008 and it is still working well, quiet and no leaks.
www.arthurgouldrebuilders.com
Old Jun 24, 2013 | 10:21 AM
ROCKET VAPOR's Avatar
Lance
And.... Karp's for the master cylinder. They will line the piston bore with a stainless steel sleeve.
http://www.karpspb.com/
Old Jun 24, 2013 | 02:12 PM
tva442's Avatar
Thanks!!
Thorton sells reproduction belts with GM markings and lists the GM part numbers on their website. I have not used these though.
http://thorntonmusclecars.com/fan-belts
Old Jun 24, 2013 | 05:19 PM
65B01Delta's Avatar
Pictures ?
Old Jun 24, 2013 | 07:19 PM
RelaxinOldsGuy
I have a post under general discussion with a photo buket link look at great barn find thanks for the tips
Old Jul 9, 2013 | 07:59 PM
RelaxinOldsGuy
I used tru-blue advise i put a auto zone water pump and the hurst still is over heating I have flushed the block and the radiator what do I do next trans will not shift into drive either
Old Jul 10, 2013 | 04:27 AM
Old School Olds
Did you change the thermostat?
Does it have it's fan shroud?
You may want to take the radiator
to a shop and have them boil it out.
On the trans, check the line to the modulator
at the rear pass side. Make sure it doesn't have
any cracks, and is pulling a strong vaccume from
the intake manifold. After sitting so long, it could
have gone bad too.
Old Jul 10, 2013 | 06:53 AM
firefrost gold's Avatar
I would Try a pressure test on the cooling system . I would also look at the timing I had a pontiac stretch the chain out and it would over heat
re timed it ran fine till it stretched again ?
Old Jul 10, 2013 | 06:02 PM
RelaxinOldsGuy
All good ideas. I have changed the thermostat and put a 195 degree in it. it does have fan shroud. My weekend starts tomorrow and i think I will have the radiator boiled check vaccum lines and put a vaccum gauge on it and a timming light and see where we are at. did everybody find the pictures on my other post
Old Jul 21, 2013 | 08:52 PM
RelaxinOldsGuy
Its mine I have paper work in hand I think i have fixed trans issues added all we vaccume lines and it shifts now. I made it miles with out it over heating
Old Jul 22, 2013 | 01:21 PM
Old School Olds
Cool. Glad you got it figured out.
Fitzy
Dec 2, 2017 08:11 PM
69442C
Feb 2, 2015 05:45 AM
vette427400
Apr 6, 2012 11:19 AM
socalpops
Sep 21, 2007 10:07 AM
