- radio light
- Fuel Pump Question
- Interior trim ? 970-b
- identifying factory cams
- Oil pressure drop overnight, re prime?
- 67 cutlass
- Oldsmobile 98 1958 shock absorbers
- Old mechanic needs help!!
- a couple questions
- "Nut Buster" tests
- dual gate console
- 56 Olds 88 Water Pump?
- 69 A/C fan R&R
- help
- 72 convertible resto
- 72 Front Grilles
- Simple, but I'm new to these cars:
- Core support patch
- 72 Cutlass conv top bleeding
- 1967 400 with the .921 lifters
- Need some help decoding No.
- Cam gear vs distributor gear
- gas pedal
- Replacing core support 72 cutlass convertible
- Dash Black paint 69
- ECM function
- Any concrete evidence the W32 was built at all plants
- grease fittings
- What is wrong with my 1975 Cutlass Supreme?
- Question...are these oldsmobile 350 engine brackets??
- Rear Axle bearing snafu
- Wheel cylinder replacement in the rust belt
- Engine I.D.
- 69 cutlass fan shroud ?
- Reference manuals for a frame off restoration
- Need help with a simple question on wheatherstiping
- 70-72 tail light mud shields
- 71 cutlass slight overheating
- Proper location for 71 72 cutlass sport mirrors
- Torque Converter Issue?
- 1986 Olds 442 Carb
- Suspension question...
- 69 442 M21 with A/C question
- Ever see something like this before?
- Help decode my fisher body data plate please
- Rally wheels bezel
- How much do you take out to remove Evaporator? 67 Cutlass
- Decoded 99% of cowl tag. But need help
- Flexplate Dust cover, 200R4/455
- Shock Information
- Cowl Tag Cease
- Cutlass U code
- Help with PCV grommets etc.
- What #'s must match?
- Rear control arm braces
- 57 Olds Flex Plate to Crank
- G - Body Speedo Issue
- Gas gauge
- 64 starfire window question
- Rear bearing question...
- 1975 Olds Delta 88 Royale Convert
- 2-speed versus 3-speed trans. steering column
- 1966 Olds horn button removal
- intake
- heater fan switch
- Best performance spark plugs for 1984 Delta 307
- Correct application for unkown nut?
- 1984 Ninety-Eight Power Seats
- Fuel Tank Strap bolts.....
- POV Air Conditioning 1966 Toronado
- Mechanical fuel pump replacment
- Magnaflow
- W30 red inner Fenders?
- Fuel Tank Question
- A/C question
- Thermostat housing bolt holes differ
- Need help reading my cowl tag for 75 olds cutlass
- Decode firewall tag
- Electrical Problem - 62 starfire convertible
- 65 442 fender chrome removal
- '70 442 Power Trunk Release Parts / Pictures
- Trunk lid question
- Parts for 1974 88 delta convertible quarter windows
- 330 #3 heads valley pan gasket
- Differential capacity
- 1970 Cutlass Supreme Radiator Support Mount
- Diff pics for Id help
- 72 Cutlass convertible Window Tilt?
- Oldsmobile Diesel Production End?
- turbo 400 Kick down question
- Washer pump hose hook up
- what carb is correct for 1070 455 auto/manual
- Brakes
- 59 olds super88
- data plate 1966 toronado
- Seatbelt Upgrades
- Any experiences with a Summit Carb?
- Where can these be bought
- Torque specs please...68 Cutlass,
- why can't I get my timing mark to 0 degrees after pulling the distributor
- throttle for 1965 442
- 66 toro trans dip stick
- Speedometer Interchange Experience
- 4 speed Rallyes?
- Camshaft
- Removal
- 1970 442 convertible glove box insignia
- 71 Cutlass Timing
- 56 olds trim removal help needed
- Need a Second Opinion/Advise
- Trans. dip stick 66 toro
- Overheating issue 1970 cutlass s 350 & others
- 65 auto shifter
- Holley etc on a Edelbrock 3711
- Deck Lid 70 convertible
- the best heads for a 455 olds?
- Offenhauser 360?
- '66 Delta Accelerator problem
- fel-pro 1356 intake gasket or valley pan
- steps for dropping the distributor on my 455 olds
- Ventilation
- Convertible top stops off & on.
- 70-72 bigblock fender braces
- windshield wiper blade refills
- 1970 Cutlass Emblems
- Steering gear end cap leak 66-442
- windshield Wiper Wiring
- Ac exchange
- Fan Shroud I.D.
- Rochester Quadrajet Carb ID question
- starfire engine in my 66 442
- Do these headers look familiar?
- Gas tank
- Was there a pass. side chrome mirror for 70-72
- convertible top motor
- Buckle up
- What wires are these???
- Build sheet
- my motor smokes a lil upon start up but eventually stops is that normal
- cruise control servo rod
- Gas tank
- Olds "O" Type Rear Disc Brake Conversion
- Ok why not tighten lower control arm bolts before on the ground
- 1979 oldsmobile regency 98 - slow to start - cause?
- broken license plate frame - any way to recast this?
- Cost for timing gear replacement
- bench seat conversion
- Muffler Question
- 68-69 W30/31 Hood Insulation Delete Documentation
- cam torque
- '66 442 steering shaft grd. For horn
- '66 442 missing turn cancel cam
- wheel openings
- wheel openings
- control arm bushings
- Exhaust fumes are terrible
- What is the name/part number of the felt like material that wipes the window?
- bumpers
- smallblock build
- wiper motor gaskets
- 69 cutlass 3 spoke 4 spoke wheel ?
- 1973 Oldsmobile Delta 88 Royale.......wheel question
- Heater ducting question
- Engine codes
- Harrison Radiator Correct?
- Grinding noise from dash while driving
- Ignition Module--87 Delta
- 49-50 Olds rear suspension
- 77-90 RWD BC Body IP Cluster
- Proper Trim For a 1972 SSIII Spare Tire
- 455 engine..what kinda carb??
- 442 paint decode
- Battery Tube Bracket Color
- 1698 Speedometer
- 1964 Assembly Manual
- vacuum lines
- Old Cans of R-12
- Can I play?
- need 1977 service manual
- 66 442 coolant overflow option
- Stripped head bolt
- Quadrajet tubes from intake manifold
- Octane Booster
- 330 ci. engine commonality
- 1967 442 build sheet
- Intermittent Cut Out
- 1968 Olds Cutlass S Fan Blade
- 1967 cutlass cowl tag help
- 1966 Dash Pad Restoration
- Hardware part numbers
- Edelbrock 1407 TV Cable Kick Down Bracket issue
- floor vents?
- neutral safety switch
- Some book suggestions for
- Exhaust Question again
- 73 98 regency brakes
- A/c recirc. Air door diaphragm - 66 442
- What are these exactly?
- Another Questions (Exhaust)
- Engine issue....please help
- Rear Suspension? Problem / Question
- 1953 Olds Super 88 Air Intake Cables
- 1964 starfire convertilbe help
- Serial number question
- 1956 olds windshield wiper help
- 1971SX Convertible
- Will 71 Steel Grill Fit a 72?
- Exhaust Question
- Deck filler panel questions
- 71 Fuel Pumps
- '70 442 Gas Tank
- 1960 Ninety Eight Spindle Nut
- 1985 Delta 88 307 engine help
- window limiter adjustments
- bolt finishes?
- Sluggish response
- 225/75-14 Tires
- HELP! lol.
- 66 Radiator Shroud
- 1975 W-30 questions
- power windows
- 1967 Cutlass vs 442 Front Bumper
- 1940 Oldsmobile Woody Wagon
- W25 Hood bumpers
- dual exhaust
- Tilt steering wheel I.D.
- can a hardtop door fit on a convertible??
- Cold Air Intake
- vacuum diagram 1957 j2
- Brake Booster Bolts/Studs
- 7040257
- Quick motor mount info needed.
- '59 Olds brake lights slow to turn off
- Optimum mileage drivetrain combos - ideas?
- 425 bore sizes
- Silver Zinc Plated Rotors?
- 1956 Turn Signal Wiring Question
- Air Dam Reinforcement - what does it do and does anyone have one?
- door fitment
- Rear Brake Drums the Same?
- Need HELP trying to figure out matching #s 1969-442
- How do I identify the correct radiator for a '71 442?
- 1967 f85
- 64 f 85 4dr deluxe and olds cutlass
- Model cars
- Toro Vs. A Body carb differences
- Buildsheet Request
- Hood Width
- 1972 Grille Emblems
- Wiper Motor Decal For "72
