can a hardtop door fit on a convertible??
Old Feb 12, 2012 | 12:18 PM
jayleo_4's Avatar
hey fellas. question for all... I proudly own a 65 Olds Cutlass. I bought a parts car Hardtop Cutlass for the convertible. Now i want to know if i remove the both doors from the hardtop will it fit on the convertible?? because on the hardtop its a power window and the convertible is manual. before i even take the doors off i wanted some suggestions. Your help is always appreciated.
respect fully J'
Old Feb 12, 2012 | 01:12 PM
2blu442's Avatar
I'm not as well versed in the 1964-65 stuff as 70-72. If there is a difference it will likely be in the wing window. I know the 70-72 convertible windshields are different than the hardtop ones. If you have them both there I'd take some measurements to see. John
Old Feb 12, 2012 | 01:58 PM
66400's Avatar
Door shells are the same, you'll have to switch glass and regulators to make the swap.
Henry
Old Feb 13, 2012 | 06:28 AM
You also need to transfer the wedge plate from the rear edge of the convertible door.
Old Feb 13, 2012 | 07:28 AM
jayleo_4's Avatar
Didnt realize it, even though both cars are CUTLASS, body style is diffrent, I wanted to and I will, add the power window on the convertible from the hardtop...
Thank all you guys!!!
Old Feb 13, 2012 | 07:48 AM
Oldsmaniac's Avatar
I did use non post 64 doors on a 64 conv and changed nothing. Glass is curved like the conv... That was many years ago but I think my memory is correct. This was a 64 Cutlass
Old Feb 13, 2012 | 08:01 AM
aliensatemybuick's Avatar
"me somebody" site member
That's the ONLY thing I would have expected would be different. I had a '66 convertible with a hardtop coupe door, noted it was not drilled for those plates.
Old Feb 13, 2012 | 08:35 AM
jayleo_4's Avatar
So basically, thats the only diffrent?? I hate to do all the work and find out that its not the right size. I was told that Convertible and Hardtop may be diffrent like in inches ?? I just want to avoid all the heavy work. I notice that I would need to drill a hole for the wirering (Power window) for the convertible.
the more information i can get, the better!..
I'm aiming completion of summer of this year. I want to take my family on our convertible Cutlass. Kids are exited!!!!
Old Feb 13, 2012 | 09:34 AM
allyolds68's Avatar
I don't know 65's but does the vent window frame have to be swtiched too. I know 68's & 69's have convertible specific vent window frames
Old Feb 13, 2012 | 07:51 PM
66400's Avatar
64-65 door shell hdtp and convert 4492510-1 same!
64-65 vent window assembly hdtp and convert 4411072-3 same!
64-65 door glass hdtp 4474600-1 clear bolt on style
4474602-3 tinted bolt on stlye
4407671-2 clear bonded style
4407673-4 tinted bonded style
different!
64-65 door glass convert 4474604-5 clear bolt on style
4474606-7 tinted bolt on style
4405052-3 clear bonded style
4405054-5 tinted bonded style
Bonded style has the glass glued to lower sash, bolt on attaches to lower sash with nuts. Convert and hdtp rear window regulators do not interchange.
Henry
Old Feb 14, 2012 | 07:09 AM
jayleo_4's Avatar
Thumbs up
different!
GOOD INFORMATION!!!!!!!
the more the better to be aware off!
CRH
Jan 30, 2018 09:27 PM
2blu442
Sep 9, 2014 09:16 PM
BCBigBlock
Body work
Jul 28, 2013 06:09 AM
