1956 Turn Signal Wiring Question
Hope this is the right section for my question...
Can anybody please tell me which wires attach to this turn signal switch?
I'm not using a stock wiring harness, so I'm kinda dead in the water.
The colors on the switch are:
Yellow
Red
Orange
White
Light Blue
Green
Thanks a lot, Martin
EDIT: Not sure why it shows upside down. Sorry about that.
Yellow
Red
Orange
White
Light Blue
Green
Here's what I got from my manual.
Yellow = LH turn, front
Red = LH turn & stop, rear
Orange = flasher
White = stop light switch
Light blue = RH turn, front
Green = RH turn & stop, rear
Lets see how well it scanned.
Orange = flasher
Thanks again, Highwayman!
I finally got to wire the signal today, and everything works!
Can't tell you how happy I am about it.
I did have a problem with the horn though.
When I hook the green wire from the column to the horn switch wire from the harness, the horn is on as soon as I hook up the battery. Kinda annoying.
Is there any part (relay,...) that I'm missing?
There is a horn relay with 3 terminals.
Green from horn button to relay coil.
Red is battery 12V+ to relay coil and contact arm.
Black 12V+ from contact arm to horns. Horns ground at frame.
The horn button in the wheel goes to ground, so off the top I don't know where the horns would get 12V without the relay. Green wire from column should be normally open and go to ground when horn button is pressed.
Not really. I'll have to buy one at the store.
Here are a couple more pics:
Intake off to be drilled.
PCV system added.
Back together.
Ready to go back in the truck.
PCV system added.
Back together.
turn signal dashboard lights
I got the turn signals to work on my 56 Super 88, but now both the dashboard turn signal indicators flash at the same time whether on left or on right. I know I saw this problem in here somewhere, but I didn't have the problem then and I can't find the solution now.
Anyone run into this before?
Thanks,
Frank
Thanks,
Frank
Frank, with both dash indicators flashing at the same time, what are the turn signals doing outside on all 4 corners? The front turn signals are on the same wire from the column switch as the dash indicators.
Also try the turn signals with the park lights on and see if anything else weird happens.
Highwayman,
The turn signals work correctly with and without the parking lights on. Nothing wierd on the exterior. It's just that both dash indicators flash for turns.
Could it be the switch itself?
Frank
Frank
Frank,
I don't think the turn signal switch is the problem. There are 6 wires on the switch. 1 is 12V from the brake light switch, 1 is 12V from the flasher and the other 4 go to the 4 corners of the car. The dash indicators simply branch off of the front turn signal wires.
However, and I had to look at this a couple of times, the flasher has 3 lugs. One is 12V Batt, one supplies 12V to the turn signal switch and the third ties to both dash indicators. I don't fully understand what is going on but since it is the only thing I see in common with both dash indicators, try changing the flasher. At least it's relatively inexpensive and easy to do.
I access this site on a daily basis and I very much like to see conclusions to questions asked.
So, I'm putting the Super 88 away for the winter, and never did resolve the issue of the dashboard turn signals both blinking. I've tried two NAPA 550 flashers. Nuttin.
Following Highway's logic, I bought a Tung-Sol NOS P273D on Ebay. IT WORKS.
Frank
Frank
