PDA
View Full Version : General Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21
  1. water temp sending port
  2. breather element
  3. wire wheels
  4. Assembly manual question
  5. Restoring 4 Spoke Sport Steering Wheel
  6. Drip Rail Weatherstrip
  7. Ingition coil help
  8. Fisher Cowl Tag Decoding
  9. How Gears work
  10. Pressure Gas Tank
  11. Top frame installation
  12. Pro Products Harmonic Dampers
  13. No cooling system pressure
  14. Cable from Steering Column to Transmission
  15. Gas backwash on fill up
  16. Sun Distributor Tester
  17. Help, moan from rebuilt steering box (long).
  18. 1966 442 Starter Wiring
  19. Help keying out floor shifters
  20. Hard shifting
  21. key code need help
  22. W-29 Stripe Kit for 72 Olds
  23. decoding 1964 oldsmobile f85 cutlass cowl tag
  24. Scissor Top Blues....Help Please
  25. W-20 Stripe kit
  26. New Secondaries
  27. speedometer calibration
  28. 70-72 Cutlass/442 radiators
  29. Timing Test 1970 455
  30. proportioning valve
  31. 1969 AM/FM 8 track
  32. 1970 cutlass ac box harrison decal location?
  33. 86 Custom Cruiser Towing
  34. Exhaust Manifold Bolts
  35. 73 455 timing questions?
  36. Carburetor questions
  37. buttons or no buttons
  38. New Springs
  39. Where to hook up EGR
  40. Convertible Top Latch Replacement
  41. Was AM/FM available in '65 F-85 models?
  42. Good quality side mirrors
  43. 1966 442 front lower A arms
  44. Michigan crankshaft bearings
  45. Fender Emblems
  46. 71 Borg stock clock question
  47. How much is a 69 cutlass steering wheel worth?
  48. how to adjust rockers and push rods on a 350?
  49. what heads do i have ?
  50. help installing fenders
  51. Safety in Slow Idle Tuning
  52. 64 F-85 coupe/VC rear bumper interchange???
  53. lgn.lock
  54. VIN and washer fluid question
  55. Data tag photo
  56. Day Night Mirror
  57. Carb info help
  58. 1964 Olds Cutlass Slow Idle Linkage
  59. Odds and Ends
  60. what pulley will work?
  61. Center Console Removal (72 cutlass vert)
  62. 72 Cutlass Convertible Rear Seat Removal
  63. A car, B-C car or E car?
  64. Suspension and Stance
  65. 68 442 rear end dimensions
  66. Q-Jet Value?
  67. Fuel line bending tool
  68. Rally Pac Illumination
  69. Complete Rocker Panel
  70. batwing ailr cleaner decal location
  71. 1991 cutlass supreme coupe
  72. '57 olds dash
  73. Lansing Build Dates
  74. build sheet locations?
  75. Take a look at these ProComp Heads....
  76. '70 Cutlass dash question
  77. Steering wheel play
  78. 1980 olds 442 w30
  79. Need experts' help on 68 Big Car mirrors
  80. Odd? Is this a 67 or a 66 Cutlass?
  81. Difference in Carb Castings
  82. sedan vs coupe
  83. alignment specs, 1976 A chassis
  84. Cad plating on a carburetor
  85. Bucket seat brackets 70 442
  86. Help removing rear windows in 71 cutlass
  87. Pilot bearing
  88. Vacuum in Radiator
  89. steering column
  90. Fuel Pump Pressure Test 1970 4 Barrel Qjet
  91. Carb Cleaning Question
  92. Tracing down history of car
  93. Q-Jets to stay away from?
  94. Carb. Parts Quality - Who's Experienced?
  95. Vacuum wipers on 54 Super 88
  96. Not Converting to Floor Shift Speedo!
  97. Code 55 interior paint
  98. Tempreture Sensor
  99. 72 cutlass a/c heater control
  100. Where to buy gold engine paint ?
  101. Jack mech. And jack base colors
  102. Quadrajet Books
  103. 68 toronado olds sways
  104. 1970 F85 Decode? Painted roof?
  105. Air cleaner vacuum hose question
  106. shock bolt nuts
  107. gas tank question
  108. Fuse box for 67
  109. '68 Air Cleaner Ink Stamp
  110. Plating my wiper mptor end frame
  111. ss1 rims
  112. 84 cutlass dipstick location help
  113. muncie 4 speed
  114. radiator seals?
  115. Steering Wheel/Column Question
  116. Steering Wheel question
  117. Repo ss 1 wheels
  118. 1972 cutlass nos EXPANSION VALVE part
  119. Temp sending unit connector 1970 455
  120. Two questions ...
  121. More 57 Questions
  122. convertible window adjustment
  123. HELP - Cannot put steering wheel back on
  124. '69 Cutlass S engine paint question
  125. 59 Fuel Guage
  126. 69 cutlass convertible PS door mirror
  127. Anybody know if this is an Oldsmobile part?
  128. 57 questions
  129. Neutral lock out switch adjustment.
  130. Kenne Bell Olds head ?????
  131. ProComp heads on a SBO 350
  132. heard of engine builder cmengines?
  133. 1964 442 power steering
  134. Advance curve on Adjustable Vacuum Advance
  135. 69 442 W30 Ram Air air cleaner?????
  136. Octane level
  137. Stock tire size
  138. 1970 Bucket Seat Question
  139. What's the difference between these models?
  140. day/night bevelled mirror 1970 Cutlass
  141. '64 & '65 Cutlass fenders
  142. 68 442 sport coupe
  143. Upper cowl chrome trim screws
  144. Lower Deflecter Material
  145. Mondello Technical Reference Manual
  146. Fan shroud clearance issue
  147. GM Service Parts Identification Codes
  148. Decode for me?
  149. console
  150. Second VIN on '50 Olds?
  151. 68 442 fender emblems - NOS or Reproduction
  152. Crank Case Ventilation
  153. Exhaust manifold gasket
  154. Converting power to manual windows
  155. convertible top replacement
  156. Fuel filter replacement
  157. 1970 cutlass grill assembly manual photo
  158. Tag installation on Posi Upgrade
  159. Is Lucas high zinc hot rod and classic oil any good?
  160. Headlight switch from dash removal ?
  161. Electric Fan
  162. Drive Shaft Stripes
  163. No Spark assistance
  164. 72 Washer Hose Style
  165. Crane Vacuum advance
  166. 330 in a 76 omega
  167. 68/69 Dual Snorkel Questions
  168. AC/Heater/Fan Box Doesn't Fit
  169. Tachometer Wiring
  170. Holiday coupe
  171. Frame Off Restoration Basics?
  172. Floor pan replacement
  173. Part number vs casting number
  174. Tilt column "cover" stuck
  175. Series
  176. 71 Cutlass A/C Restore or Upgrade??
  177. Triangle Air Filter
  178. 65 cutlass canadian 442?
  179. Upper and lower radiator hose springs
  180. Front License Plate Bracket/Frame 74/75
  181. LED Headlights
  182. Gas tank
  183. Battery tray help
  184. wiring information
  185. Rear Spoiler template and placement.
  186. 1963 Power antenna ?
  187. 3 row for a 394?
  188. Need convertible top installed 1970 442 NW Indiana
  189. Carb ID
  190. Inner fenders Cutlass
  191. 1983 cutlass supreme 2dr vacume house routing diagram needed
  192. 68 350 oil pan dent
  193. Matching Numbers?
  194. installing reproduction red inner fenders for a 71 442 on a 72 supreme
  195. 62 Starfire mufflers
  196. swapping 76 grill/front to 75 olds 98
  197. 69 442 Build Sheet?
  198. SS 11 Bezels.
  199. Starter Painting
  200. 63 Starfire - Noise in Steering - Help!
  201. 62 Starfire door light switch
  202. Exhaust System Kits - Do They Actually Fit?
  203. 1965 Cutlass/442 speedo head circuit board
  204. Bolt sizes
  205. Best Valve Cover Gasket
  206. Anyone near San Diego who can ehlp me out?
  207. Phoenix graphic stencil kit 1972 442
  208. New to site and need help with 55' parts locate
  209. Too many adds
  210. Car will not start at ignition switch but will when hot wired?Help!
  211. Trim Tag Decode for 64 Jetstar
  212. 1972 Bendix metering valve rebuild
  213. seeking car performance Accelerometer advice
  214. Should I buy this car?
  215. 1971 Cutlass Tail light lens
  216. Please help.
  217. '69 Supreme taillights vs. all others
  218. Dash bead
  219. Auto to Manual Wiring Concerns
  220. 68 350 tear down
  221. 70-72 W25 Hood
  222. 1955 Olds Right Hand Exhaust Manifold Question
  223. Balancing E engine qustion
  224. Brake Booster Delco/Moraine stamp
  225. 64 Olds F85 Hood Question
  226. Hei conversion.
  227. 1965 deluxe seat belt buckle
  228. 12 bolt vrs 10 bolt
  229. Glove Box Lock 71 Cutlass
  230. mouldings ?
  231. Who knows of a good place to get Bumpers rechromed
  232. changing from a at to a 4sd help
  233. 71 inner fenderwells
  234. Ignition Coil Question
  235. trunk lettering O L D S M - O B I L E
  236. Convertible Top Differences 68-72 Cutlass
  237. Cracked Holley Carburetor Spacer
  238. core support for 69 442
  239. Need help with Starfire 2 way electric seat track and linkage
  240. 74 hurst auto alarm
  241. gas tank problem
  242. Heater/AC vacuum controls
  243. Brass Fuel Tank?
  244. What are these brackets and what year do they fit?
  245. rear wheel bearings & seals
  246. roll pin installation experts
  247. 70 442 Cowl Tag
  248. electric vs mechanical fuel pump
  249. prop valve fitting adapter
  250. Fuse Box - How to clean 65 442
