69 cutlass convertible PS door mirror
I have a 69 cutlass s convertible, is there supposed to be a PS mirror? If so, could someone post a picture. Mine does not have one and I'd like to install one.
Also note that very few cars had that passenger side mirror back in the day. Now I hate to drive without it but, back then, almost everybody did!
As well, the passenger side mirror was available only with the manually controlled mirror. If you have a remote controlled mirror on your driver side, the passenger side non-remote mirror won't match.
Randy C.
Randy C.
Here's what the drivers side remote mirror looks like
Then here's the non-remote one. These are being reproduced.
If you buy used make sure your getting the correct ones for 68-69 as the 70-72 look very similar but have different bases. Here's a picture showing the difference between the years
2blue...In the third picture down the right hand mirror with the thicker base is a 68-69 right?
Which is which in the pic where your holding the mirrors in your hand? I think the 60313401 left mirror is the 68-69 right? Can you post the numbers off the 68-69. TX
Oct 16, 2013 05:35 PM
nitrojunkie1029
Tech Editor's Desk
Nov 2, 2011 01:38 PM
stlbluesbrother
Dec 24, 2009 05:47 AM
