330 in a 76 omega
Old Jan 10, 2013 | 12:37 PM
tru-blue 442's Avatar
Old School Olds
330 in a 76 omega
Hey fellas.
A quick question:
I have a friend who would like to drop in a 67 330
into his 76 Omega with a 260 in place now.
I told him I didn't think there would be a problem
as long as he kept all the brackets, pullys, intake
and exhaust manifolds from the 260.
My question is will the exhaust manifolds, flywheel and engine mounts
from the 260 work with the 330 on the swap? And anything that won't?
Thanks as always guys, Adam.
Old Jan 10, 2013 | 05:51 PM
2blu442's Avatar
The flywheel won't. The 330 has the early crankshaft bolt pattern, so only the 330, 65-67 400's and 425's will work. But once he bolts that on, everything else will fit with it. Starter, transmission or if a 4 speed the clutch and transmission.
The 330 intake would have a different choke setup with the carb, so he'll need to change that or use a 1966-67 carb. Everything else should swap just fine.
John
Old Jan 10, 2013 | 06:26 PM
Old School Olds
Thanks for the reply John.
It is truly appriciated, Adam.
omega74
Sep 12, 2015 08:51 PM
QS442
Nov 9, 2013 06:11 AM
restoman
Oct 7, 2009 01:34 PM
<Brian>
Sep 9, 2004 09:38 AM
<CHRIS L.>
Mar 5, 2004 03:15 PM
