prop valve fitting adapter
Old Sep 30, 2012 | 07:11 PM
montvaleplace's Avatar
I have a 70 vista that I am moving the proportioning valve from the frame rail to under the master. I have a stainless rear feed line with the fat fitting where it usually threads into the prop valve and am looking for a fitting to convert it to a 1/4 line. I know it could be cut and reflared but was hoping someone knows of a retrofit fitting. Thanks..
Old Oct 1, 2012 | 11:41 AM
The part you are looking for is frequently called a "master cylinder adapter fitting". NAPA stores have a plastic box full of them in their brass fittings section if the person behind the counter knows what he is doing. You can also find them on line - do a Google search.
Old Oct 2, 2012 | 06:55 PM
Thats great, I'll check it out tomorrow. Thank you...
nofiveo
Jul 28, 2011 02:08 PM
OLDSmobility
Brakes/Hydraulic Systems
Apr 29, 2011 08:15 AM
olds67
Mar 6, 2011 12:58 AM
69Rman
Dec 11, 2010 08:48 PM
joe_padavano
Jul 1, 2009 10:10 AM
