A car, B-C car or E car?
Old Apr 10, 2013 | 06:07 PM
jjokrm's Avatar
That is the question. How do you know which one you have? I was looking at my 68' assembly manual to reference the power steering bracket set-up and it has different scenarios that are dependent upon which car you have; A, B-C or E car?
Old Apr 10, 2013 | 06:10 PM
starfire's Avatar
F-85/Cutlass = A body
88 = B body
98 = C body
Toronado = E body
Old Apr 10, 2013 | 06:39 PM
jjokrm's Avatar
88 = B body
98 = C body
Toronado = E body
Awesome! Thanks!
Old Apr 12, 2013 | 10:28 AM
It's even a "sticky":
GM Car and Truck Platforms
Old Apr 12, 2013 | 11:05 AM
88 = B body
98 = C body
Toronado = E body
I believe VC and Cutlass Flattop falls into A body and Custom Cruiser falls into C body.
Old Apr 12, 2013 | 01:51 PM
Correct
That's less clear cut. The 1977-1996 Custom Cruisers are technically B-body cars (sharing the same 116" wheelbase as the B-body sedans), but in reality the only difference between the B-body, C-body, and D-body cars in that time frame is the wheelbase. They are otherwise mechanically identical and share body parts forward of the rear doors.
I'm less well versed in the 71-76 CCs, but again, the B-body/C-body distinction is primarily wheelbase and trim level.
Old Apr 12, 2013 | 02:10 PM
I was inclined to lump the Custom Cruiser into the C body simply based on the body lines matching the Ninety Eight. That's really evident from 71-76 but when the bodies started becoming more 'generically similar' in 77 - 85 I agree the CC could be said to be more Delta related. Anyway, that's my line of reasoning and its just an opinion based on observation.
I did note that some references to the GM C body alluded that the CC and Ninety eight were simply 'stretched' versions of the B body platform. So your comment about wheelbase may be spot on.
Old Apr 12, 2013 | 07:58 PM
starfire's Avatar
Hey Joe, what's the body designation for your '62 F-85?
Old Apr 12, 2013 | 08:26 PM
Alan, I believe the f85 was designated as an A body starting in 1961. Let's see what JP says.
Old Apr 13, 2013 | 05:51 AM
Actually, the 61-63 compacts (F-85, Tempest, and Skylark) shared the Y-body designation (and platform) with the Corvair. I see that the list in my post is incorrect. I'll fix that.
Old Apr 13, 2013 | 06:01 AM
starfire's Avatar
Do you mean "Z"? Your list has the Corvette listed as "Y".
And did they make a Corvair as late as '69? (Sorry, I know nothing about Chevys).
Old Apr 13, 2013 | 06:17 AM
Yup. Note sidemarker lights:
The Corvair was replaced directly (though late in the year) by the Vega:
pic from here
Old Apr 13, 2013 | 07:47 AM
I did mean "Y", which is why I need to correct the list.
And while the Corvair was produced through the 1969 model year, side marker lights were federally required with the 1968 model year.
Old Apr 13, 2013 | 08:26 AM
I know, but there is no other "evidence" of 1969 production that I could show in a photo, since headrests were optional in '68, as far as I know, and I think Corvair somehow avoided having to use a column-mounted ignition switch.
I'm no Corvair expert, but I don't think there were trim differences between '68 and '69 either.
