A car, B-C car or E car?
That is the question. How do you know which one you have? I was looking at my 68' assembly manual to reference the power steering bracket set-up and it has different scenarios that are dependent upon which car you have; A, B-C or E car?
Correct
That's less clear cut. The 1977-1996 Custom Cruisers are technically B-body cars (sharing the same 116" wheelbase as the B-body sedans), but in reality the only difference between the B-body, C-body, and D-body cars in that time frame is the wheelbase. They are otherwise mechanically identical and share body parts forward of the rear doors.
I'm less well versed in the 71-76 CCs, but again, the B-body/C-body distinction is primarily wheelbase and trim level.
and Custom Cruiser falls into C body.
I was inclined to lump the Custom Cruiser into the C body simply based on the body lines matching the Ninety Eight. That's really evident from 71-76 but when the bodies started becoming more 'generically similar' in 77 - 85 I agree the CC could be said to be more Delta related. Anyway, that's my line of reasoning and its just an opinion based on observation.
I did note that some references to the GM C body alluded that the CC and Ninety eight were simply 'stretched' versions of the B body platform. So your comment about wheelbase may be spot on.
Yup. Note sidemarker lights:
The Corvair was replaced directly (though late in the year) by the Vega:
pic from here
pic from here
And while the Corvair was produced through the 1969 model year, side marker lights were federally required with the 1968 model year.
I'm no Corvair expert, but I don't think there were trim differences between '68 and '69 either.
