72 Washer Hose Style
Anyone know if the original washer hoses that go from the pump to the squirters were black, with print on them or white (or any other color) striped in 72? My 68 Hurst still has the OE ones and they're white striped, but the kit I bought from ILT has plain black hose. Thanks in advance.
Joe/Scott
I was doing some searching on the stripes on vacuum lines etc and found a tool that does all this . It's made by Beugler and is a pin striping wheel that will put the stripes on in any color you want. On a side note though it's pretty expensive so unless I'm going to stripe a couple hundred feet of hose I'll pretty much buy them from ILT.
Joe - Scott sells really nice stuff. I bought some new rubber striped hose from him last fall and am really happy with it. I don't think the squirters had stripes - just the ribs like Scott mentioned. I know you're doing a concourse resto, so check with Scott to see if they're new or used.
Scott I'll take a set of the nicest you might have. Also, haveyou had a Chance to find that convertible coat hook? PM me with a total. Thanks!!
