- a/c vents not working
- Need help decoding 1972 Olds body tag
- Speedo stuck at 30
- shifter/trans measurement needed
- Hole Size for power window conversion
- Seat Belt Question
- How would I identify a straight 8 flywheel
- Washer pump problem
- horn is staying on
- Need help identifying connection
- Ground Strap behind Control Panel (72 Cutlass)
- Gauge vs idiot light switch
- Mig welder question: What amperage?
- dash recovering
- Looking for an education - '69 W30 carbs?
- 1970- 1972 front fenders dimensions
- 4gc carb
- Olds Intake Manifold 1973 - Dumb Question
- Sealing pan gaskets?
- 1969 442 build sheet/broadcast card/P-O-P
- Anyone with info on this fender?
- 1970 A Body Headlamp Bucket Finish/Jack Colors
- Frozen Distributor
- 1968 door window channel removal
- cutlass window stops
- Quadrajet fuel filter leakage
- Brake Booster Replacement
- Atomic EFI
- 1966 442 tri power oai
- 1957 1958 front bench seat questions??
- Where's the screens?
- What doors fit?
- Hot Start with new Carb
- Wiper/Pump motors
- '67 olds cutlass supreme
- '85 442 G-body brake line to rear dimension?
- 455 Pistons
- 1970 Cutlass upper vent cable on kick panel
- please help id an engine
- Oil pump gear questions
- Help Installing Windshield and Back-glass Reveal Moldings
- 1970 Fremont where is the build sheet?
- Which bracket for AC compressor
- Engine casting dates confusion
- 1956 Frame Differences
- 1969 oldsmobile rear defroster switch
- Points to HEI Distributor problem
- Option Combinations
- What is the purpose of these keys?
- Power conversion help needed
- SE Michigan Convertible Top Replacement Resource
- Great Oldsmobile pick today! Rallye 350
- Swing Pitch
- head light install
- Cloth Elctrical Tape advice
- F40 HD Suspension
- HEI e-bay purchase went defective
- "Low Coolant" light
- Need some help with metal fuel line fittings...
- frame numbers
- 1953 Oldsmobile Steering Column
- Spark Plugs
- motor mounts
- Carb rebuild
- 72 Cutlass Carb - 750?
- Storing empty gas tank
- AC compressor weight
- e bay HEi into pre HEi 71 455 Olds....HEi complete from E Bay
- increasing distributor total advnce to 36 degrees
- Distributor order of spark plug wires
- Correct Finish / Color On A '70 442 PVS
- 1964 seats and console same as
- Working OE Horns On A 70 442 -Any Advice On How To Refinish Without Damaging
- high resolution wiring diagram
- How do I remove the dash pad in 1971 Cutlass?
- how do i do front wheel bearing replacement on 1972 culass
- 1971 442 Misc Parts Finishes: Which is correct?
- Crimestopper SP 302 Alarm
- trunk release
- Tapping into dash connector
- OE 70 442 Harrison Radiator Tag Questions
- 73 olds delta royale p/s mirror
- 68 442 ignition lock cylinder removal
- Door Panel Repair chrome strips
- Need advice on body removal
- Got Rear Ended. Body Shop Recommendations? Where to get parts?
- screw type ?
- Headliner removal to check for paperwork
- headlamp bezel argent paint
- 1964 CSM question
- Grounding of tachometer lead
- Firewall Grommet replacement
- 70 cutlass wagon dual action gate question
- Fusible Link Power Top Relay Starter Relay
- carb code
- AC delete Can I remove Vac can on firewall?
- Reverse lights are alway on with key in the "on" position
- making tribute 68 442 - what emblems are right?
- noise...
- Basic information
- Antenna
- 72 convertible cutlass top motor
- Wheel cover problem
- Doing it the right way
- Diesel Oil Filter Housing
- 1964 330(310 hp) distributor on a 1974 455
- 71 Olds 350 flywheel cover
- Clips for molding on 67 442
- 71 Cutlass convertible top question
- Thread Sealants? What is best for this application?
- 73 olds 455 A/C evaporator temperature sensor
- Flathead head bolt Q?
- Alternator belt alignment
- Nut & bolt size
- Ignition only when releasing key...
- Vista Cruiser window removal
- what size faN
- Jack slipped while rasing front end
- Front cabin heat from engine compartment
- data plate
- tick tock tach need help
- 1966 oldsmobile 98 steering column schematic needed
- What Is This Part??
- power steering pump pulley
- 1969 Cutlass S post car
- 68 hurst engine color
- 1962 Oldsmobile 98 cowl tag decode
- Bumper jack
- Bumper Question
- Heater controls - connect 2 or 3 cables?
- No air flow
- 70 442 wheel paint
- Parts interchange with other GM makes
- Window regulator/Gauge
- HELP! Suddenly got lots of issues.
- neutral safety switch 1971
- j-hook spare tire holder
- 57 olds air cleaner
- Part numbers for 68 Olds
- ridge reamer?
- 1970 455 Ignition Coil Wiring
- 1968 442 wing and window HELP!!
- bulb socket
- Alternator and Power Steering Belts?
- Inner fender well
- Windsdhield wiper question
- 1967 442 post coupes
- 1965 olds 98 advance/dist problem
- 69 Vacuum Trunk release
- 71 442 w30
- Peculiar Non-starting Non-cranking situation
- Gas gauge not reading correctly
- HEI Dstributor Questions
- Lower Control Arm vs Down Pipes
- Need weather stripping instructions
- 1964 394/4V matted to a 1959 jetaway.
- Motor mount header clearance
- 70 Safety Sentinel Speedometer
- AEM A/F fine tuning the Qjet question
- removing power steering box from pitman arm
- Benefits to changing flex plate
- Holley vs. Edlebrock Carburetor " 1972 Cutlass "
- use factory resistor wire to trigger relay for HEI
- Copper A/C Heater Core Purchase Warning
- help identifying lines in engine bay
- Odometer Repair
- 1965 4sp. Crankshafts
- Correct hose clamp style
- Ignition switch stuck
- Help with more Horsepower
- p.s. belt length?
- fan clutch question
- 1964 Jetstar 88 Ignition switch
- ARP head stud kit and OEM "stud end" bolts
- Starter Rebuild or buy Remanufactured?
- What color is the power trunk release button 71 442
- 53 rocket 88 radiator
- 68 442 : Dual-snorkel air cleaner housing?
- 1970 Cutlass Floor Jack lift point Rear
- Dizzy Adjustable vacuum advance??
- Hooker headers install question
- Need measurement with removed right fender liner please
- Best Rochester QuadroJet carburator to use
- Windshield Wiper water bottle for 68 442
- Dizzy Questin-How much play ia normall?
- Wheel Clearance
- Rocket Racing Valve covers
- Fan & shroud clearance on 70 350 cutlass
- Question: Toro 455 to Engine Stand
- Rally Wheel Serial Number Decoding
- 71 Cutlass Conv top shop
- Cruise control levers interchangeability.
- Oil Pump Shaft. Which one to use?
- Re: Fan shroud removal
- Radiator fitment
- Hydroboost brakes
- T-3 and Amber Headlights
- 1955 dash removal?
- Best way to fix a sticking throttle cable
- Lightning Rods HELP
- Question about W-25 hoods
- do 98 fenders fit 88's in 63
- Driveshaft lengths
- Wanted71/72 cutlass wiper motor decal info
- 65 442 ? on ebay
- Fan & shroud clearance A Body 1968
- Quadrajet?
- 70 442 Core Support Bolt Markings - Is This Right?
- Engine Builder
- 1966 Cutlass Drum Brakes-Brake Tool?
- electric roof problems
- 1970 W30 verification
- Vacuum readings on Q-Jet video
- Q-Jet Auto Choke Install Question
- Crankshaft
- Q-Jet Rebuilt, before and after PIC’s tuning with vacuum gauge
- Headlight Removal 1962 Starfire
- Milodon Pan
- Removal of chrome (stainless)
- Front shock lower bolts not seated
- Pilot Bearing OEM or Bronze Bushing
- 83 Cutlass AC Slide Switch Broken
- Electric Fuel Pump
- Edelbrock swap for Quadrajet 66 Olds 425
- 1971 442 Battery Tray Spacers
- 350 Main bearing question
- Number of Hood Insulation retainers required?
- Dual Gate Shifter
- Bucket Seat Rails Question
- 1970 Cutlass Ignition Lock Cylinder Replacement
- 1967 Toronado Cruise Control
- Help on Dual gate shifter
- Lower Radiator Hose
- Msd controller hei Dist what's it all mean
- Header fitment on a 71 cutlass
- 1964 Cutlass driveshaft
- Torque spec for front disc castle spindle nut
- Weird DSAC on FeePay
- A question of provenance, what engine, when?
- Converting from column shift to console shift
- Water pump question
- Mysterious coolant consumption/loss
- Score Moog 5386 for $44
- Outside Door Handle Buttons
- HELP!!350 Olds engine brackets!!
- Heater core hose placement
- 4 speed
- Proform 66955 HEI Shaft Dia/Gear ID
- Do SBO/BBO share any pieces with Buick 455?
- Jetaway and an ST300....?
