1966 oldsmobile 98 steering column schematic needed
Old Apr 22, 2014 | 06:26 AM
The Flash's Avatar
anyone have a manual or schematic?
turn signals are not working
there is a cable that goes to the lever in the column
after i pulled the wheel there are some pieces sitting at the bottom of the cover
before i tear is down more i wanted to see an manual on it
thanks
Old Apr 22, 2014 | 06:36 AM
Oldsguy's Avatar
Past Administrator
The factory service manual would give you everything you would need to know to fix that and then you would have it for future repairs on your car too. Good investment.
Old Apr 22, 2014 | 07:54 AM
Oldsmaniac's Avatar
Check www.wildaboutcars.com for the service manual on line.
Old May 17, 2014 | 04:30 PM
cfair's Avatar
You can get PDFs of the 66 Chassis Service manual online
Go to wildaboutcars.com an see their tech library for olds. Treasure trove of manuals and build data.
Best I've ever seen
Cf
Old May 19, 2014 | 04:39 AM
The Flash's Avatar
thanks
starfire
Dec 9, 2021 08:21 PM
shamusj
Apr 27, 2021 05:45 AM
317Cutty
Jun 18, 2014 10:53 AM
ros6872
Mar 28, 2014 09:48 AM
oddball
Mar 4, 2014 06:42 AM
