help identifying lines in engine bay
Old Mar 26, 2014 | 06:49 AM
86odls's Avatar
i was getting ready to drop the motor back in last night and noticed two metal hoses in the engine bay. there's a small one and a bigger one and the big one is cut in half. what are these lines?
Old Mar 26, 2014 | 07:03 AM
Professur's Avatar
You're kidding, right?
Old Mar 26, 2014 | 07:05 AM
86odls's Avatar
what?
Old Mar 26, 2014 | 07:19 AM
Uh, there are a lot of "metal hoses" (also called tubes) in the engine compartment. Perhaps you can provide a photo that will let us provide a useful answer.
Old Mar 26, 2014 | 07:28 AM
86odls's Avatar
Old Mar 26, 2014 | 08:18 AM
70cutty's Avatar
Beer Connoisseur
try posting the photo again. I don't know about everybody else but it doesn't show on my screen.
Old Mar 26, 2014 | 08:24 AM
86odls's Avatar
https://www.google.com/search?q=engi...ml%3B680%3B480
Your "image" file is apparently a link to the Robert Powers Motorsports website. Again, can you post a photo of YOUR car and the specific tubes you are referring to.
Old Mar 26, 2014 | 08:30 AM
86odls's Avatar
I don't have one and im not in a position to take one right now
Old Mar 26, 2014 | 08:34 AM
Kinda hard to help then, based on the limited info. Are you talking about the fuel lines on the passenger side frame rail, or something else?
Old Mar 26, 2014 | 08:37 AM
70cutty's Avatar
Beer Connoisseur
Or maybe tranny cooling lines?
Old Mar 26, 2014 | 08:52 AM
Unfortunately, the mind reading thing still isn't working.
Old Mar 26, 2014 | 09:08 AM
86odls's Avatar
it right under the oilpan iwere the motor mounts are welded onto
Old Mar 26, 2014 | 09:17 AM
NHolds's Avatar
The line that goes under the engine ...motor mount side to motor mount side is your brake line.
Old Mar 26, 2014 | 09:39 AM
Model and year of car????
If it is the brake lines he's talking about, this is the time to replace them while it's convenient. Nothing worse than pouring in brake fluid and watching it leak all over the frame and floor.....
Old Mar 26, 2014 | 09:43 AM
Octania's Avatar
Some hints that might help:
Location
exact sizes
what they ARE connected to
Maybe get into a position where you can share an actual photo, what with them trading at 1000 words and all.
Old Mar 26, 2014 | 09:52 AM
70cutty's Avatar
Beer Connoisseur
Joe time to dust off your crystal ball
Old Mar 26, 2014 | 10:21 AM
86odls's Avatar
im not leaking brake fluid or anything and my brakes work perfectly fine
Old Mar 26, 2014 | 10:32 AM
NHolds's Avatar
Steel line in engine compartment:
1. Brake lines
2. Auto Trans Lines
3. AC lines
4. Fuel Lines
It's one of those...
Old Mar 26, 2014 | 11:01 AM
Professur's Avatar
Then those are probably old lines that were left in place when replacements were run parallel. Go under and look at where they lead to.
Old Mar 26, 2014 | 11:05 AM
86odls's Avatar
okay thank you for the help
Old Mar 26, 2014 | 11:48 AM
Tedd Thompson's Avatar
My money is on the transmission lines, I'm kinda clairvoyant..Still lost in the fifties ...Tedd
Old Mar 26, 2014 | 11:53 AM
Except that the trans lines are the same size and the O.P. said this in his original post:
That leads me to say fuel line and vapor or return line.
Old Mar 26, 2014 | 12:27 PM
pogo69's Avatar
morgan
dont even know what kind of vehicle it is....could be a sherman tank
Old Mar 26, 2014 | 12:38 PM
Professur's Avatar
Meh .. that hasn't stopped the rest of us speculating. So long as it's not a water buffalo, I think we're good.
Old Mar 26, 2014 | 01:56 PM
4speed455's Avatar
Going off his screen name I'm going to say it's probably an 86 Odls.
Old Mar 26, 2014 | 02:21 PM
pogo69's Avatar
morgan
right...screen names are always a dead giveaway
Old Mar 27, 2014 | 06:05 AM
86odls's Avatar
i spelled it wrong but it is and i traced the lines and i think its the smog controll lines
JpMotorsports
Mar 31, 2016 07:17 AM
joepenoso
Jun 4, 2014 01:56 PM
dabone70
Aug 18, 2011 11:29 PM
wolfman98
Mar 9, 2009 02:03 PM
elmo
Sep 23, 2007 02:49 PM
