Torque spec for front disc castle spindle nut
Old Feb 5, 2014 | 10:03 AM
W-27's Avatar
The manual shop doesn't specify a torque reference for the front disc spindle castle nut and I guess there isn't one but I have heard tighten it than go back 1/4 of a turn as heat will expand the metal (any truth to it?) but when I do so there is a little play in the wheel. What is the correct way?
Old Feb 5, 2014 | 10:22 AM
I tighten it until there is no wobble play in the bearings and then tighten to the nearest slot in the castle nut to get cotter pin in. I like a tiny bit of preload on my wheel bearings. It's a touchy feely thing for me.
Old Feb 5, 2014 | 03:19 PM
tru-blue 442's Avatar
Old School Olds
^^X2. Tight. But not TOO tight.
Old Feb 5, 2014 | 04:17 PM
freds cutty's Avatar
You are right I don't believe that there is a spec its got to do with the amount of load the bearing has when manufactured. All bearings and races are different they should all be a matched set. I was always told to run the nut up by hand. Tighten the nut while turning the rotor until you get a slight resistance then turn nut back off to first spot where cotter pin will line up. This should give you a small load on bearing yet turn easily.
Old Feb 6, 2014 | 09:38 AM
This is the process as described in the CSM. I do have a slight variation, however. Since I always repack the bearings if I have the hub off, I tighten once while turning, back off, then tighten again per above. This way I make sure that I'm not getting a false resistance due to grease.
ysgarage.jp
Aug 19, 2015 09:00 AM
brown7373
Sep 19, 2014 07:16 AM
James A Shaw
Oct 17, 2013 10:23 AM
boese1978
Suspension & Handling
Feb 26, 2012 11:39 AM
oldzy
Mar 22, 2011 04:33 AM
