PDA
View Full Version : General Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21
  1. Classic Car Insurance Source
  2. mini starter
  3. Reverse Thread
  4. hood stencil kit
  5. '69 H/O alternator
  6. European parts vendors
  7. 54-56 starter
  8. throttle cable
  9. 83 Cutlass Supreme 307 to V6 engine SWAP
  10. 1967 Olds 425 Big Block- 45 or 39 degree??
  11. Torque Curve Diagramme
  12. top Radiator bumper
  13. Firewall to fender brace
  14. how to remove/ install new rear wheel bearings 1970 cutlass
  15. New Shocks.
  16. A/C question
  17. Exhaust Question
  18. Intake and carb
  19. Oldsmobile CanAm Engine Builder?
  20. 56 cam and lifters
  21. waterpump 455
  22. Hubcap for air cleaner top, diameters?
  23. w-27 cover bolt questions
  24. if anyone can help with a block #
  25. left turn signal control
  26. Learning to use an inside mic
  27. tire conversion chart
  28. OPGI 68-72 In Dash Tachometer
  29. drip rail removal tool
  30. 72 Toro question.
  31. j2 intake
  32. 70-71 455 ac bracket question
  33. cruise control
  34. Pictures posted
  35. transmission cooling lines to radiator
  36. electric choke on holley 4160
  37. 4 spd flywheel
  38. 66 backup lights
  39. bench to bucket conversion
  40. Vacuum Advance and a Rochester Quadrajet
  41. Part # Book 77
  42. Alternator Bracket ?
  43. tune up specs
  44. best carb to use
  45. Best practice for installing fuel line to fuel pump
  46. 55 olds98 rocker moldings
  47. Concerned About Piston Slap
  48. Hood Hinge Rear Spacer
  49. 68 headlight buckets
  50. mini starter
  51. Oil pressure sending unit
  52. My &2 Cutlass "S"
  53. Spring Start up of 64 88 dynamic
  54. Clubhouse forum
  55. 1970 olds 98 Number
  56. Rear speaker enclosure
  57. Tire and Wheel combo
  58. 86 307Y to 71 350 A/C question
  59. GM Super-lift option
  60. Lookin for intake/carb advice
  61. Anyone Know Anything About These Bumpers?
  62. 7040253 Q-jet
  63. 1970 steering column lock plate
  64. replacing a steering gearbox.
  65. VIN Production numbers, vehicle search
  66. Will 73 Cutlass 'S' Steering wheel fit 72?
  67. 1970 sport mirrors
  68. What are these parts?
  69. WIW - NOS PARTS - W-25 OAI Hood & FENDERS
  70. Passenger Window Track
  71. Will these headers fit?????
  72. 71 Delta 88 Steering Column.
  73. SEM Interior color
  74. Carb trouble?
  75. can an 85 cutlass 200-4r shifter and shift cable fit in a 87' 442?
  76. 68 442 window roller
  77. 67 442 Fuel Sending Unit - Reproduction?
  78. Convertible header bow
  79. 1973 455 leaking vacuum, how to get to shop
  80. need a Ralley Pak !
  81. 1955 Oldsmobile S88 Molding hardware
  82. California smog w-30
  83. removing paint from plastic gravel guards
  84. Rochester Carburetors
  85. Ac parts?
  86. 4BL CARB for a 371 OLDS
  87. Help cutlass wont start
  88. Interchanging carbs
  89. Knocking Sound from rear of car
  90. what color is ....
  91. Fuel pump
  92. HEI dissy
  93. Ever seen this marking?
  94. Help Identifying a 425
  95. 1941 Olds camshaft end thrust
  96. speedminder speedometer
  97. What mufflers do these sound like?
  98. More On (Not MORON) Wipers
  99. Front coil spring question(s)
  100. Vacuum Windshield Washers
  101. Radiator Core Support
  102. '67 442 Sport Coupe
  103. Paint Codes from Build Sheet (Picture)
  104. Question of Rear Ends....
  105. 64 olds cutlass
  106. Oldsmobile Manuals??
  107. is a 66 442's vin special
  108. cowl tag
  109. What year and model is this old's am/fm radio correct for?
  110. Master cylinder for '68 442 - questions
  111. Nos battery
  112. 1964 Jetstar 88 Vista cruiser Wheel
  113. How Does This Work?
  114. 1949 Remote Filter
  115. Engine number
  116. cylinder lubricnts
  117. timing V8-BB
  118. Won't start--maybe ignition?
  119. Valve cover gaskets questions- '68 442
  120. Auto to standard crank specs
  121. Z49 Mandatory Canadian Base Equipment Modifications
  122. 59 Core Support Bushings/fasteners
  123. 87 delta 88 gauges.
  124. Column shifter with buckets
  125. Delta 88 Factory 4 speed?
  126. 68 442 master cylinder source?
  127. Q-jet ID help...
  128. what aftermrket intake will fit under a oai
  129. Distributor
  130. Are there different drivers doors for the 69 cutlass?
  131. Anyone with old GM part manuals?
  132. headliner/windlace or trim???
  133. antenna
  134. weight and dimentions of 350
  135. Front Disc Brake Conversion Kit
  136. Boost chip question
  137. Inspection tags and stamps
  138. short console ?
  139. gas tank connections ?
  140. Correct Engine Color
  141. Aftermarket Rad and Electric Fans
  142. Headers
  143. Weird courtesy light problem.
  144. Radiator question...3 row, 4 row, etc...
  145. power window motor
  146. Battery suggestions
  147. date codes
  148. Line replacement costs
  149. whats the best OAI media blasting material
  150. Electronic fuel pump hook-up
  151. Evap box sticker location
  152. Converting A/C to R134
  153. Sand blasting question
  154. Roch Carb vendor?
  155. are ac and non ac valve covers different
  156. Vacuum controller
  157. 1955 Power Window Motors
  158. Dashboard Install
  159. installing dashboard on 1967 cutlass convertible
  160. question
  161. ac control panel relay
  162. 1955 Body Manual??
  163. Installing a shifter and console
  164. 1959 98 aircon
  165. Original vs Tamraz OAI Hood
  166. I hit a deer :(
  167. 55 Holiday Sedan side glass
  168. Help...Headers wont fit....on a 403
  169. 64 radiator brackets
  170. Price of bead blasting
  171. can I use my 86'' 307 olds parts on my 71'' olds 350
  172. O.A.I. Vacuum hose arrangment
  173. SS II Wheel Project
  174. Seat Belts
  175. What color for shift linkage on TH350 w/console shift?
  176. Dissassembling air cleaner
  177. 324/350 swap in my 54 Olds
  178. 64 Old Engine & Transmission ID
  179. 71 442 Alternator #
  180. witch is the correct thermostat housing for a 70 455
  181. valve help
  182. 98 Bravada Heating System
  183. Water Pump Play?
  184. Online/ PDf Chassis Service Manuals
  185. Gas tank problems!!
  186. steering intermediate shaft
  187. Is the console the same for dual gate compared single shifter ?
  188. help with clock repair .....
  189. 1964 Cutlass VIN
  190. Tuneup Decal
  191. Is an original 71 W30 radiator worth keeping?
  192. Another 70 cutlass Cowl tag question
  193. Remote Starter Switch instructions
  194. console hinge screws
  195. HELP PLS! 70 cutlass convert rear seat interchange
  196. INFO PLEASE!! 70 power window motor numbers
  197. '75 Cutlass running warm?
  198. miss firing in the secondarys .....
  199. Identify this 88 emblem
  200. melted alt wire, voltage reg clicking
  201. Missing trunk key
  202. 71 cutlass 350 rocket to 455 upgrade ??
  203. Unknown fastener/clip
  204. Radiator,pushing water out over flow
  205. 65 Cutlass post rear window channel
  206. Found: OAI air filters
  207. Quadrajet Tuning
  208. Tutorial on changing alternator and power steering belts?
  209. Motor mount bolts
  210. wheels
  211. 200R4 in '65 442?
  212. Repro Disc Brake Proportioning Valves for my '72 Olds
  213. Recommendations - Chicago area
  214. how to take this trim off
  215. heater hose routing
  216. Identify these parts
  217. '68 Delmont Ventillation Vacuum Diagram desperately needed!!!
  218. 66olds master cylinder
  219. Water Pump
  220. post doors 64-65
  221. 67 Cutlass trunk Light
  222. Free Online Service Manuals 1964 - 1972
  223. Wipers and Windows Won't only Work on Acc
  224. Rear posi not working anymore
  225. 57 olds vacuum diagram needed
  226. t shifter
  227. i need a vacuum hose diagram
  228. Question: Gas Pedal
  229. 72 cutlass overflow - what are you using?
  230. '65 Bumper Mounts fit a '67???
  231. 83 H/O..Cutlass parts?
  232. Help ID this driver's Remote mirror 65-67 ?
  233. power antenna
  234. Uncovered an engine...what is it?
  235. Fuel Problem
  236. Parts from a 98 that swap into a Cutlass
  237. q-jet probs
  238. new to convertible
  239. hydraulic leak in convertible top
  240. Confused about Carb
  241. How many...
  242. 1972 custlass s steering column questions
  243. Horn Mounting Location on 72 Cutlass
  244. Autometer GS Gauges
  245. Rebuilt or New carb Source
  246. 72 442 metal dash paint
  247. convertble top help
  248. front fender to radiator support
  249. Fan Belt/Drive Belt???
  250. Electric fan hookup???
