71 cutlass 350 rocket to 455 upgrade ??
Old Sep 27, 2010 | 09:49 PM
davepnola's Avatar
I have a 71 cutlass with 350 rocket with 350 auto trans and a 71 rebuilt 455 long block with intake ready to go...... What can I use from small block ( water pump, flywheel , motor mounts , etc...) and what will I need to upgrade for the big block ..... the car has headers now , will they work with the big block or are the ports or bolt pattern on the header to small ?? thanks
Old Sep 28, 2010 | 02:16 AM
64Rocket's Avatar
Just as you listed, mounts, water pump, pulleys, alt. brkts, power steering pump and brkts and flexplate. the radiator also, if it is the 3 or 4 core rad. even if you have A/C all that stuff will bolt right on. The headers are different story. They will bolt to the heads but you will have clearence problems, because of the big block and small block deck height.
Gene
Old Sep 28, 2010 | 02:48 AM
redoldsman's Avatar
Proud Viet Nam Veteran
There are a number of threads here on this swap. It has been covered several times. You should probably replace the Turbo 350 since it will not hold up behind the 455.
Old Sep 28, 2010 | 10:25 AM
davepnola's Avatar
headers will not work or can they be modified to work ?? anyway to tell .....
Old Sep 28, 2010 | 10:33 AM
svnt442's Avatar
It would be WAY more work than it's worth to try and modify the 350 headers because all of the tubes would need to be cut and lengthened. And some may need to be re-routed.
Just sell them and buy a set for a 455.
Old Sep 28, 2010 | 10:51 AM
davepnola's Avatar
Ok where can i buy a set this week shipped to louisiana ...thanks
Old Sep 29, 2010 | 12:11 AM
64Rocket's Avatar
Summit or Jegs
Gene
deadeyejedi
Feb 21, 2014 03:29 PM
mechanicman81
Mar 3, 2011 07:35 PM
cutlass1972s
Jul 6, 2010 06:33 PM
glassjaw442
Apr 12, 2009 04:48 PM
