71 cutlass 350 rocket to 455 upgrade ??
I have a 71 cutlass with 350 rocket with 350 auto trans and a 71 rebuilt 455 long block with intake ready to go...... What can I use from small block ( water pump, flywheel , motor mounts , etc...) and what will I need to upgrade for the big block ..... the car has headers now , will they work with the big block or are the ports or bolt pattern on the header to small ?? thanks
Just as you listed, mounts, water pump, pulleys, alt. brkts, power steering pump and brkts and flexplate. the radiator also, if it is the 3 or 4 core rad. even if you have A/C all that stuff will bolt right on. The headers are different story. They will bolt to the heads but you will have clearence problems, because of the big block and small block deck height.
Gene
Gene
It would be WAY more work than it's worth to try and modify the 350 headers because all of the tubes would need to be cut and lengthened. And some may need to be re-routed.
Just sell them and buy a set for a 455.
perchhead
Mar 29, 2013 03:14 PM
cutlass1972s
Jul 6, 2010 06:33 PM
