melted alt wire, voltage reg clicking
melted a wire and damn near had a fire, when the wire melted it melted the plastic oil pressure line wrapped up in the loom. filled the intake manifold full of oil, noticed the huge cloud of smoke when i accelerated and the oil dumped on the hot exhaust. pulled the plug from the alt, and folded the good oil pressure line twice and taped it, made it home. the voltage reg is clicking when the bat cable is connected. alternator is/was new, where do i look?
I can't recall my wiring colors right now, but I believe you burned up your field wire.
That shouldn't be possible with a good alternator - if the regulator is mistakenly sending full voltage to the field coil, it still shouldn't be enough to melt the wire, unless there was a short in the alternator.
Check everything, though, and slit the harness to be sure the hot wire didn't cause any other shorts.
Good luck!
edit: I think I needed to be clearer -
This is NOT your main output wire, which means that your alternator was NOT putting out way too much current to the system, and therefore that the short is not likely to be in the rest of the car, but is likely to be in the charging system itself (although the heat could have caused another short somewhere else)
Good luck!
so i pulled the old wiring out, it wasnt the feild wire but the R wire? only melted a foot and a half in but melted real bad there, too bad to see anything. checked my parts car and it had an original unmolested, unpainted, harness. will put it in tonite and start checkinq everything else. hey 442 scotty i googled M&H, what else is in their name?
thanx for the link for wiring, awsome. okay new harness went in and everything worked for a minute, then the starter ran on when the key was turned on????? i guess with the hei that went in it didnt like the wires together at the coil location now,it had been separated on the old harness. now its all good just need to run a new line for the oil pressure
