need a Ralley Pak !
Old Feb 2, 2011 | 02:15 PM
knighthawk's Avatar
From: from Wisc, then Texas, then Kansas, now back to Texas,
need a Ralley Pak !
Is there another source for the 'ralley pak 'gauges ? ('69 cutlass) other than Year One ? as they are on back order since last Nov. ! Eveidently there aren't enough on order for the manufacturing company to make any !!! so., I need a lot of you out there to order some,,,,,,, or,,,,,,, tell me where else I can get them ????????????thanks
Old Feb 2, 2011 | 02:50 PM
Lady72nRob71's Avatar
Did you try the Parts Place? I ~think~ they have some for a '69...
Old Feb 2, 2011 | 03:06 PM
Cr099's Avatar
Try www.ros6872parts.com for an original...
Old Feb 2, 2011 | 04:02 PM
oldsconv's Avatar
Parts Place in Illinois as stated above. $429 and they actually have them made. Year One buys from them so you probably pay more getting from Year One.
Old Feb 2, 2011 | 04:26 PM
knighthawk's Avatar
my computor VERY slow today....can you get me the number for the parts place ?.. .......... never mind , I got it ,,,thanks again !
Last edited by knighthawk; Feb 2, 2011 at 04:44 PM. Reason: computor slow, but working
Old Feb 2, 2011 | 07:01 PM
ROCKET VAPOR's Avatar
Lance
IIRC, GM Sports makes the '69 tachometer here in the USA for $195.00.
http://www.gmsportssalvage.com/?q=node/1317
Now....I do not know how correct of a reproduction this is though.
Old Feb 3, 2011 | 12:37 PM
bigdaves442's Avatar
I got a set of rallye Pac gauges from Parts Place in my 442. Look great, work great and no problems what so ever(have had them two years). Not very hard to install either.
Oldscov is correct that Parts Place makes the gauges themselves (They are the cheapest) and sell them to all the other Olds reproduction companies like Year One.
Old Feb 3, 2011 | 03:27 PM
knighthawk's Avatar
I just ordered the gauges from Parts Place.thanks .and they were cheaper
Old Feb 4, 2011 | 06:46 AM
The Gauges look and work good but the only problem you find is that the backlighting isn't as bright as the speedo (the tach is super hard to read at night). I never understood why until i read Rob's & AcesHigh's threads that show you how to take them apart and fix the problem by painting the inside white & Blue and replacing the bulbs (going to be one of my spring projects).
Here are their links:
https://classicoldsmobile.com/forums...tml#post130178
Old Feb 4, 2011 | 01:03 PM
knighthawk's Avatar
I read that once before ,,(painting the inside ), I actually forgot about it till you mentioned it, thanks
miked
Aug 22, 2012 08:29 AM
knighthawk
Jul 22, 2011 09:11 PM
miked
May 31, 2011 07:56 AM
Longhorncutlass
Jun 16, 2010 11:55 AM
815Cutlass1972
Paint
Apr 2, 2010 08:18 AM
