Engine number
Old Dec 29, 2010 | 02:45 AM
chevyman's Avatar
Engine number
Hi, I just got a real nice 59 dynamic 88 coupe.it has a 371 cu/in engine in it I would like to know the following.
1, Where on the motor is the engine #
2, Will a J2 manifold and carbs fit the 371 engine
3, How can I tell if it has the standard engine or the Super 88
engine in it
4, In the past I have always bought parts of Fusicks is there a
better place to buy Oldsmobile parts
Thanks for any help cheers Noel
Old Dec 29, 2010 | 08:37 PM
59-59-59's Avatar
To identify the size, check the top of the extended bell housing in back of the engine.. if you see a 4 at the end of a number sequence, its a 371 - if you see a 4 1/8 its a 394.. 371 were gold and 394 were greenish in color.. Also on the left cylinder head, if it stamped on a pad with a C its a 371... a D is a 394. You cannot fit a '57-'58 manifold on the 'new' 371 of that year - its the first year of a 'tall deck' engine block as opposed to a short deck. Fusick has alot of quality parts, but the mechanical parts they have are overpriced and can be found cheaper elsewhere
Alg
Jan 1, 2013 05:04 PM
marcello
Ninety-Eight
Sep 5, 2008 05:20 AM
roadster-rob
Mar 9, 2008 10:24 PM
perro
May 2, 2007 02:39 PM
1BAD68"S"
Sep 17, 2006 06:49 AM
