FIND VIN AND ENGINE NUMBER
HY,
MY NAME IS MARCELLO FROM ITALY
I'VE BUIED IN USA AN OLD
OLDSMOBILE
NINETY EIGHT
YEAR: 1957
VIN 579M16501
SERIAL NUMBER 16501
I FOUND THEESE INFORMATION BY DIGIT VIN NUMBER IN WEB SITE :http://www.v8cars.hu/oldsvin/vin.php
COULD YOU HELP ME TO FIND WHERE IN THE CAR I CAN FIND:
- THE VIN NUMBER
- THE ENGINE NUMBER
I MUST FIND THEM BECAUSE I HAVE TO MAKE REGISTRATION IN ITALY
I SEE A VIN PLATE:
In the left front door hinge pillar.
BUT I NEED TO FIND WHERE IT IS ON THE CHASSIS
AND FIND WHERE IN THE ENGINE IS THE NUMBER
THANKS VERY MUCH
MARCELLO
ITALY
OLDSMOBILE
NINETY EIGHT
YEAR: 1957
VIN 579M16501
SERIAL NUMBER 16501
- THE VIN NUMBER
- THE ENGINE NUMBER
I SEE A VIN PLATE:
THANKS VERY MUCH
MARCELLO
ITALY
Hi Marcello,
'57 Olds 98 is my favourite. I also bought '57 Holiday 98 earlier this year.
'57 car serial number plate is located on the left front door pillar as you
said. The body and style numbers are stamped on a plate wich is located
under the hood on the cowl near the right hood hinge. Is there any other
plates? I don't think so. Your's 98 was made in Lansing, Michigan in 1957.
The engine serial number is stamped on a machine pad on the top of the left cylinder bank between the center and rear exhaust manifold ports.
- Mika
- Mika
should be in the lower left hand corner of the windshield.
Engine VIN is above the # 1 spark plug on 68 and up, don't know about earlier than that.
Here's a pic It's on the left side of the motor
hi ,
could i send you a photo of which numbers i find?
Because i research the vin numbers print on the chassis (not on a slab), the same for the engine number . i need your email to send you the photo of what i have found , thanks very much!!
Marcello
Marcello
olds53rocket
Dec 22, 2006 05:46 PM
