PDA
View Full Version : General Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21
  1. Hood trim
  2. leak
  3. did olds BB cars come with a BB steering shaft
  4. is this a original 70 cutlass am/fm radio??
  5. 68 442 fuel pump question
  6. Starfire and GM Bucket Seats
  7. Decode this '64 body tag
  8. Fuel pump W-30
  9. 2 more things PLEASE HELP almost done fixing everything
  10. 1954-55 rear bumper swap ?
  11. builld dates and motor specs?
  12. looking for paper work
  13. 57 Olds model/Vin info
  14. 72 442 trunk lid emblem measuremente
  15. 1966 Tripower Oil Fill Tube
  16. cutlass is really fustrating me
  17. R46S Spark Plugs
  18. 57 olds heater blower motor
  19. Glass date codes
  20. Please Help-Won't Start
  21. Dual Gate Shifter
  22. Access to A/C Receiver-Drier on 68 Cutlass
  23. hood hinge color on a 70 cutlass
  24. Block Filler
  25. Heater Fan Housing Fasteners
  26. repair manuals
  27. Looking for A/C part #
  28. will w z manifolds fit on a 330
  29. want to sell 76 Starfire
  30. 65 cutlass convertible parts??
  31. what power glide tranny will fit my 66 f85
  32. needing pics
  33. Valve cover swap
  34. Patriot side exhaust help
  35. Question on attached plate?
  36. 72 442 windshieldwiper hose routing
  37. What other cars can I use the pedals from?
  38. Cast or forged?
  39. de-codeing my 72 98 help!
  40. th350 shifting problem...fixed!! just fyi...
  41. Motor oil???
  42. Windshield wipers mystery
  43. Tire question
  44. Cowl tag mystery
  45. Anyone know what this Olds part is?
  46. Can't remove fuel sending unit from tank.
  47. Cam Specs
  48. Engine shake at idle
  49. Missing parts book pages. Book "66 thru 70"
  50. body tag de-coding
  51. Canadian oil change decal
  52. convertable top
  53. OAI Hood and W30 Hoods Question
  54. Door Question
  55. 73 delta 88 heater control
  56. How Much Does it Weigh...69 Olds
  57. How rare is this pulley?
  58. Vacuum hose
  59. I have this GM rim - any idea what it's for?
  60. 330 CID vacuum
  61. Leaded Gas
  62. Air Cleaner Color
  63. Flywheel ID?
  64. 65 Cutlass choke tube/heat riser/carb tube
  65. Timing marks?
  66. Brackets
  67. Improve dash illumination
  68. I just don't know Jack
  69. 64 f85 radiator question
  70. No Hole In Hubcap
  71. Spark Plugs
  72. Kace
  73. Steering Box Leak - 70 Cutlass
  74. 1965 Starfire
  75. Interchange in 1988 Cutlass and 1988 98
  76. 1956 Olds runs at full choke only!
  77. lost book
  78. Olds 403 distributer tuning
  79. canadian window sticker?
  80. Intake manifokd cstg. no
  81. quarter pannel replacement
  82. Help for identification
  83. 55Olds - Poor running can you help?
  84. Hood latch removal help
  85. data plate decoding
  86. Belt diagram for a 1967 Cutlass Supreme
  87. heavy duty radiator for 55 olds
  88. 70-72 repro instrument cluster bezel
  89. A-Arm Shaft and stuff
  90. Need help identifying ps brackets
  91. Build sequence number
  92. Block Casting Number
  93. 67 Cutlass Radiator Support
  94. Interior Question 67 Cutlass
  95. speedo correction
  96. 1956 Super 88 vaccum window washer Hookup
  97. Rochester to edelbrock
  98. Spark Plugs
  99. 61 62 88 The Same Chassis?
  100. vin tag
  101. vin number 1965 starfire
  102. another Olds site
  103. Egr
  104. Quadrajet
  105. Canister leaking charcoal?
  106. flywheel??
  107. 1968 Cutlass Project
  108. Any Toro Gurus here?....1970
  109. 1960 Olds loss of power in corner only
  110. correct radiator for 67 442
  111. '75 Salon steering box
  112. 68-72 350 exhaust manifold question
  113. car keeps shutting off!
  114. Old Gold
  115. Thoughts on Springs
  116. hood spring question
  117. front inner wheel well help
  118. Gas gauge
  119. firewall hole?
  120. need a fast answer...
  121. Oldsmobile Trunk Letters
  122. Tires - Bias Ply to Radial
  123. Fuel/Vapor Line Clips
  124. Carb Choke Cover Missing?
  125. Canister Purge Solenoid 3800 V6
  126. production information question...??
  127. Washer Jar from Fusick
  128. headers for 403cid?
  129. Lower Ball Joint/Coil Spring Removal (Help)
  130. Carb swap: that is the question.
  131. 350 olds small block......
  132. Correct color for light gaskets
  133. 1968 Olds Cutlass S Font
  134. Gas leaking from fuel tank vent tube?
  135. 1964 Olds Cowl Tag paint code
  136. Wheelbase
  137. Quadrajet Rebuild
  138. Holley carb help
  139. Quadrajet mounting gasket question (with picture)
  140. question with package tray installation
  141. brake booster
  142. Brake System Setup
  143. '72 Cutlass Convertible Window Adjustment
  144. GM HEI interchange???
  145. build sheet
  146. Intake manifold coating
  147. Questions on dual exhaust
  148. 1972 442 Spatter paint color?
  149. 1965 425 with 1968 455 c heads
  150. heater cable
  151. bellhousing question
  152. Correct factory air cleaner housing colors
  153. Question - 1964 Olds
  154. 1972 Radiator Overflow Jug Location
  155. Two questions on 72 Cutlass Convertable
  156. '75 Salon seat belt covers
  157. Blasting media
  158. Charcoal Cannister question
  159. 57 Olds J2 VIN
  160. Choke Tube 65 330
  161. Gasoline with Ethanol question
  162. 1pc or 2pc main fuel line for 72 Cutlass Supreme?
  163. trying to id the olds
  164. Trailering a 70 Cutlass S
  165. Do i Need a Harmonic Balancer??
  166. What heads
  167. Backup lights
  168. Cowl tag data (Fremont)
  169. Tachometer question
  170. Adjusting MSD Pro Billet PN 8566 adv. curve
  171. KPH Speedo for my 1975 Cutlass?
  172. 1967 442 Carb vacuum lines..... HELP!
  173. Brake/Fuel Lines... OE Steel or Stainless Steel?
  174. Having trouble...
  175. Conv Top adjustment
  176. Sorry another stripe question
  177. rare options
  178. data plate decoding
  179. Sticker and Lincense Plate
  180. OAI hood/what brand?
  181. Dash Guages
  182. Heater core for 1963 Cutlass F-85
  183. Y60 Option
  184. Air Compressor Setup...
  185. What year is Part No. 410629 (Rocket Emblem) from??
  186. TH400 conversion to overdrive unit
  187. Air Cleaner Vacuum Diaphragm-72 Cutlass
  188. 1969 Wheels
  189. 68-69 moldings
  190. 394 - 371 Olds Oil Pan Question
  191. 3j67m2m217448
  192. Help With Cowl Tag decoding 1968 Cutlass S
  193. Help with factory codes for '68 442
  194. Olds Underhood Finishes
  195. which rear drum
  196. 350 Headers
  197. convertable quarters
  198. Cornering Lamps
  199. Why No overflow ..?
  200. Chassis and Body Manuals? Who's Best?
  201. Oil Filter Question
  202. 1967 delta 88 antenna
  203. Wiring harness
  204. heater core help??
  205. speedometer dust cap
  206. hurst olds mirrors
  207. 303 Olds Mallory dual pont conversion kit..
  208. Q-jet????
  209. Disk Brake Conversions
  210. Olds rod dimensions question
  211. OIL!!!
  212. quick question about noise in differential
  213. Difference between cutlass and 442
  214. just looking for some advice
  215. No build sheet
  216. pinion gear for the rear
  217. big block sm block a/c brackets
  218. SPEEDOMETER CABLE
  219. friend's 71 442 W30 blew something last night
  220. 330 to 455 component swap
  221. Similar years to the 1969 Cutlass Supreme Holiday Hartop for finding parts?
  222. SPEEDO NEEDLE
  223. 1969 98 exhaust
  224. tire size for 1969 olds 98
  225. Where to get 67 Cutlass fender moulding fastners ?
  226. Why are 57-62 Turn Signal switches so rare?
  227. Cowl Tag info please
  228. Modern paint code ?
  229. Heater Core
  230. Please Help
  231. front coil springs
  232. ignitor 2
  233. Picture of 70 442 Jack
  234. digital dash
  235. dual exhaust
  236. 1966 Cutlass/442 Console PRNDL
  237. One more Bumper Jack
  238. What about this Bumper Jack
  239. Correct Bumper Jack 70 442
  240. receiver dryer replacement question
  241. 64 post rear qtrs.
  242. similarities of pontiac and olds motor
  243. '72 442 questions
  244. 403 brackets
  245. Installing upper rear main seal
  246. Price difference between parts suppliers
  247. modulater valve problem?
  248. Console wiring
  249. Dash Harness 66 442
  250. steering columns
