350 olds small block......
Old Mar 27, 2010 | 10:18 AM
iron eagle's Avatar
Here's a question:
Is it possible to fit an 350 chevy block instead of a 350 oldblock in a vista cruiser? I've got a 1971 Vista Cruiser.
Old Mar 27, 2010 | 11:39 AM
lshlsh2's Avatar
71 cutlass convertible
Yes it is possible but it requires alot of extra work. The trans is different along with moter mounts and hose routings and other things. It will be simpler to rebuild your 350 or just go get a 455.
If it were mine I would use it as an excuse to put a 455 in it. A 455 swap is even simplar than a 350 che*y swap.
PS you won't get much help for the che*y swap.
Larry
Old Mar 27, 2010 | 12:02 PM
70 cutlass s's Avatar
It's no big deal, but you will need all the brackets for it non of the Olds will work on it. You will need a Chevy transmission also. New Chevy engine mounts. The exhaust manifolds are different so your exhaust won't bolt up. You'll need to take it to a exhaust shop.
Old Mar 27, 2010 | 11:52 PM
svnt442's Avatar
The harness is different, starter is on the wrong side so you have to move the battery........in short if you're looking to save money you won't with all that would need to be done to accomplish the swap.
Old Mar 28, 2010 | 06:49 AM
2blu442's Avatar
From your location I'm thinking you may be having a hard time finding an Oldsmobile engine. John
Old Mar 28, 2010 | 10:06 AM
iron eagle's Avatar
Well that's exactly my problem..........
It's impossible to find an engine for my car.
The only block afforable is an 403 block, but that doesn't fit at all I think?????
Sorry for the dumb questions, but I'm used to having a mopar (that's all the same)..........
Old Mar 28, 2010 | 10:10 AM
The 403 will fit. With no problems.
Old Mar 28, 2010 | 10:23 AM
80_cutlass's Avatar
In fact, no problems might be an understatement.
sb
Old Mar 28, 2010 | 10:24 AM
iron eagle's Avatar
sb
What do you mean by that?
Old Mar 28, 2010 | 10:27 AM
dan2286's Avatar
They are externally the same, everything from the 350 will bolt onto the 403.
Old Mar 28, 2010 | 10:31 AM
iron eagle's Avatar
Ok great. Then I'm gonna call the guy with the 403 block. Maybe it's still for sale.
Thanks guys!
bocoogto
Aug 26, 2023 06:09 PM
TicTocTach
Jan 31, 2014 10:19 AM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
citcapp
Jan 31, 2009 04:01 PM
