hood spring question
Old Apr 11, 2010 | 03:59 PM
WTony's Avatar
Just installed a fiberglass 70 OAI hood on my 69 wagon. Bought a pair of aftermarket springs that are supposed to support the hood. They do not. Almost lost my head, but luclily was able to grab the hood before it crashed onto the locks.
My questions are, does a stock steel hood take the same hood springs as OEM 70 OAI hood?
This hood has a full fiberglass frame and air box. It weighs 45# only. Do you think stock springs would work?
Does anyone have sources for diffrent spring rate hood springs?
Thanks!
Old Apr 11, 2010 | 07:34 PM
Olds luvr's Avatar
Grown Azz Kid
Hey, I have an all glass hood and had the stock springs on and they were too tight. I bought ones for the all glass hood but have not inataled them yet...
Old Apr 11, 2010 | 09:41 PM
The stock steel hood and the factory 'glass hood take different springs, using the stock steel hood springs on the 'glass hood will result in stress cracks near the hinge area.
Old Apr 12, 2010 | 12:16 AM
Wasted's Avatar
Maybe they sent you springs that were to weak. Where did you get the springs at? I believe I got mine from Rock Auto and I haven't had a problem with them yet.
Old Apr 12, 2010 | 01:08 AM
Bluevista's Avatar
Registered
The factory OAI hood uses the same spring and hinge as the steel hood according to the Olds parts catalog?
The Parts Place '70 hood with the steel frame uses the stock hinges and springs.
Tht hood is just too light for stock and too heavy for the aftermarket lightweight springs it seems?
Maybe some worn out stick springs would do it?
Not sure if heat would take some tension out like some do to car springs for lowering or if it could create more problems.
Old Apr 12, 2010 | 04:46 AM
I just went round and round with the hood springs for my 69 H/O. The standards spring should have 19 turns in it. After changing out springs 4 times, I finally bent the ears on the hindge that hold the springs out just the tinyest bit and they now hold the H/O hood with the heavy fiberglass scoops.
Old Apr 12, 2010 | 07:25 AM
Olds luvr's Avatar
Grown Azz Kid
I got my "Low Tension" hood Springs from TPP. They say they are for the all glass hood so I hope mine work the way I expect them too once I get them installed
Old Apr 12, 2010 | 05:06 PM
WTony's Avatar
Bought these springs from a guy on ebay. Guess I got what I paid for huh?
It seems one of the hood hinges goes up further than the other, but when closed they both are closing evenly. The right side will open to the lock but the left one isnt all the way to the lock. When I push the hood all the way up and both hinges are fully open, the hood says up just fine. Pull it down just a little on the one side and it wants to slam shut. Bad hinge or just not adjusted correctly? I remember that with the stock hood and springs, the hood didnt want to stay open too good either. When I pulled the hood down more than 6" it would want to slam shut. Maybe both hinges bad?
Old Apr 12, 2010 | 05:36 PM
stevengerard's Avatar
I thought the hinges were the same but the springs were different, this is one of those items that seems to have three answers all the time.
oldspackrat
Sep 13, 2020 05:23 PM
johnnyjaws
Feb 23, 2015 04:30 PM
HitTheHole
Jan 9, 2015 06:36 PM
Z-Fitch
Oct 1, 2011 02:37 AM
Longhorncutlass
Mar 2, 2009 01:53 PM
