Egr
Old Apr 26, 2010 | 01:25 PM
kenrod's Avatar
Egr
Anyone know where I can get a EGR block off plate.
Kenny
Old Apr 26, 2010 | 01:46 PM
80_cutlass's Avatar
With a little massaging you can use a fuel pump block off as an EGR block off. That's what I did. Or you can cut one from 1/4" aluminum or 3/16" steel.
sb
Old Apr 26, 2010 | 01:49 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have a few home made ones here, but if you want a fancy one, Jim makes them. 309-361-0907
A fuel pump block off will work as well.
Old Apr 26, 2010 | 07:21 PM
71supreme's Avatar
I've just swapped to a pcv valve on mine. It seems to work nicely.
Old Apr 26, 2010 | 08:22 PM
Blk71SX's Avatar
I'm confused, can you elaborate?
Old Apr 27, 2010 | 04:54 AM
71supreme's Avatar
Hmm, I may have been thinking of something else. I was thinking of the port coming from the Pass side valve cover, which I put a pcv valve in. I don't think my 71 has an egr.
One thing I have heard of for blocking off the manifold piece was to installed the hot air choke thing and leave the tubes running to the carb off.
Mike77
Apr 30, 2024 05:54 AM
Chumley
Aug 3, 2008 01:50 PM
SX455
Sep 16, 2007 06:09 PM
81cutlassconvertable
May 26, 2007 05:16 PM
DonFrost
Ninety-Eight
Jun 22, 2006 04:16 PM
