EGR-TCV
EGR-TCV
I am looking for info on the EGR-TCV Exhaust Gas Regulator- Thermal Contol Valve. My EGR is currently installed on a 1977 Oldsmobile 403 Cu. in. It is supposed to control vacuum to the EGR at 76*F. The TCV is missing.
I am trying to figure out were it goes and what it looks like. I do know there are EGR-TVS- Thermal Vacuum Switch (100*F) or an EGR-DTVS- Distributor Thermal Vacuum Switch (120*F). These are water sensing switches located in the water passage. I don't have a port available on my block to install a water sensing switch. The vehicle is 100% original.
This leads me to believe it may sense via air temperature.
Hoping someone might have a description of the the device, or a picture, a part#, or were I could source one.
I have tried many, many on-line sources and the usual GM/Oldsmobile part distributors with no luck. I am sure it is a common part to many GM motors of that era.
Regards,Mike
Regards,Mike
Do you have one like this?But with the tabs still on.https://classicoldsmobile.com/forums...1&d=1196078594
The picture is of a 2 port Thermal Vacuum Switch TVS. I looking for a Thermal Control Valve TCV. Same but different. Actually I don't know what it looks like. Mine is missiing.
Thanks for the info
Thanks for the info
That's the one I'm looking for. I believe it just senses temperature, called a TCV.
When you say it "sits" on the timing case shelf are you meaning it does not thread into anything? The one in Jim's picture look's like it threads into the manifold or some place.
Thanks for the reply
