What heads
Old Feb 5, 2010 | 03:22 AM
KRYPTONITE's Avatar
What heads
WHAT heads should be on this 69 is there a number where I can check, also would you change the points distributor to an later model with a module in it. Better performance?
Old Feb 5, 2010 | 03:58 AM
70 cutlass s's Avatar
#5 head are the correct ones. The number will be in the lower left hand side of the driver side head. As fare as distributor you mean later. You can put an HEI in it. Pretty easy or you get an kit that converts your point dist. to electronic. A lot of people on here have and I'm sure people will give advice on both.
Old Feb 5, 2010 | 04:12 AM
KRYPTONITE's Avatar
heads
are #5 good flowing heads large or small cc any idea what ? comp ratio to 1 on this head with 350
Old Feb 5, 2010 | 04:32 AM
Well I'm thinking the #5 heads are 64cc heads with 1.875 intake valve and 1.562 exhaust valve. Which the #5 heads are good heads as they are, but with a little work and larger valves can be made into really nice heads. Your compression ratio should be around 10.25 to 1
Old Feb 5, 2010 | 05:02 AM
Destructor's Avatar
If the car came with a 2 barrel carb the compression ratio will most likely around 9:1.
Old Feb 5, 2010 | 05:42 AM
Yeah that's true. The 4 barrel carb engine had 10.25:1
Old Feb 5, 2010 | 05:56 AM
Absolutely. HEI, variable reluctance, or uni-light distributors are better than points distributors in every way. You can either go with a stock HEI distributor from a mid 70s Oldsmobile, or you can get a Pertronix kit to convert your points distributor to a variable reluctance type distributor. The good thing about the Pertronix kit is that your distributor will maintain a stock appearance.
Old Feb 17, 2010 | 07:36 PM
Warhead's Avatar
The number 5 heads (397742 casting number, located directly above center cylinder head bolt on lower row, below valve cover) will be lucky to have a chamber size of 68 cc's. The ONLY way you will be able to get a 64 cc chamber with this part is to cut the heads .030". If the heads have not been cut, and have a valve job done on them, they will usually be 70-72cc.
Fact.
This will change your compression calculations by a bit.
Jim
Old Feb 17, 2010 | 08:44 PM
Fact.
Jim
I hate to say it, but I quoted the sites tech section. I have never had a set of number 5 heads. I guess its pretty sad that the info on the site is wrong.
Old Feb 18, 2010 | 08:14 AM
Warhead's Avatar
Some day it might get corrected.
Until then, I'll squeak like an old wheel.
Hope it helped.
Jim
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
