D heads or H heads
Old Jul 29, 2009 | 07:31 AM
olds4life's Avatar
D heads or H heads
which heads are better. i have guy telling me that the D heads are better than the H heads.
Old Jul 29, 2009 | 07:50 AM
The reality is that they are equivalent. The only real difference is that the H heads have induction hardened valve seats for use with unleaded gas. Since D heads were made for two years, I'd also say that H heads are more rare. In any case, these are worth the most to a restorer. For any high performance, modified application, I'd sell the rare castings and use the money to build a motor with aftermarket heads.
Old Jul 29, 2009 | 11:31 AM
nickd's Avatar
Are C's pretty much the same as H and D then performance wise?
Old Dec 25, 2012 | 12:56 AM
Nickyloves442s's Avatar
D heads have a smaller combustion chamber, the smallest of all olds big block heads. Best if you want t gain a little compression.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
Dragonist
May 14, 2011 11:29 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
