Cast or forged?
Old Jun 21, 2010 | 10:12 PM
74glencoe's Avatar
Cast or forged?
forged pistons for reliability, correct?
is 9.75 to 1 about right for 89/91 octane?
71 olds I believe (F block, G big valve heads)
Thanks in advance guys.
Old Jun 22, 2010 | 09:22 AM
Correct. Forged pistons will handle higher cylinder pressures and are more forgiving of occasional detonation.
Old Jun 22, 2010 | 01:22 PM
Blk71SX's Avatar
provided what's coming out of the hose is what's advertised. 93 would be better.
you might check out 4032 hypereutectic pistons. I put 80,000 miles on a set in chevy sb 400 with a cr pushing 10:1. they looked excellent with very little scuffing
Old Jun 23, 2010 | 09:15 PM
74glencoe's Avatar
Where are you getting 93 octane? Gas stations around here dont carry anything higher than 91. I also need to build the engine so I can run the octane that they sell at the lake, which the higheast is 91.
Dont hyp. pistons go pretty quick with any detonation?
Old Jun 26, 2010 | 04:44 AM
88 coupe's Avatar
Junior Member
For anything under 500 HP it doesn't matter.
If the distributor is properly curved for the application, detonation will not be a problem.
Norm
Old Jul 4, 2010 | 09:04 AM
Warhead's Avatar
Norm
Very true,
This point can not be touted enough.
2 out of 3 engines do not need the parts they get sold.
If you are not making 500 hp, and going beyond 5500 rpm still making power, you just plain don't need them. If you have stock heads, you are not there.
Jim
dman0712
Dec 8, 2009 09:56 PM
Charlie_brown
Aug 22, 2009 02:43 PM
raymondh
Aug 20, 2008 03:45 AM
2blu442
Mar 1, 2008 10:55 AM
