1965 425 with 1968 455 c heads
Old Mar 4, 2010 | 01:46 PM
425cutty's Avatar
Question 1965 425 with 1968 455 c heads
I was just curious i just purchased an 1980 olds with a 425 and i was in the process of rebuilding a 455 and all i had done were the heads would the 455 heads bolt on the 425???
Old Apr 30, 2010 | 02:38 PM
olds425's Avatar
Yes they will. They should work perfect. No modification necessary.
Old May 1, 2010 | 07:01 AM
The only possible issue might be pushrod clearance, depending on the lifter bank angle of the 425. If it is a problem, simply opening up the pushrod holes in the heads solves it.
steve walker
Dec 17, 2019 12:32 PM
monzaz
Jun 27, 2012 01:03 PM
425cutty
Mar 5, 2010 04:23 PM
Jhall64
Sep 27, 2009 08:16 PM
jabba
Oct 28, 2008 11:53 PM
