- Mufflers
- 1972 Supreme molding clips
- After market tach issue
- Problem Rebuilding AC fuel pump 1961 394 engine
- 1968 442 or H/O heater hose routing and clamp
- Terrible gas mileage after carb rebuild
- Help on identifying a set of tail lights
- Vacuum trunk opener
- Vacuum Tank for 1963 Starfire
- gm rear end tag
- 1993 Ciera Problems
- Pertronix Distributor Problem
- 2.56's With W-31 Type Powertrain?
- Reassembly of '68 intermediate Steering Shaft
- Tell the Difference? '68 M20 Vs M21
- Rear view mirror
- '68 442 Brakes: Drum to Disc convert ??
- 65 olds 98 front brakes
- 1964 Oldsmobile engine swap
- Glove box lock
- Long crank. Carb is empty
- Did not expect this
- Need Help Identifying Engine parts
- 1972 A Body rear window defogger
- 69 Cutlass vent window fit
- 67-68 Cutlass Convertible Fender Emblems
- Oil pan bolt -what?
- 394 with a stuck-in-block distributor!?!?!?
- 1984 307 vacuum routing
- High speed relay
- Distributor identification
- What Brand of Water Pump?
- Oil dipstick oil level
- 67 cutlass won't start when hot light is on...
- 1970 Lansing Engine Pad & Transmission Stamps
- 1972 W30 Radiator & Tag Question
- 68-442
- Looking For A 71 Cutlass Expert
- Steel wheel
- Glove box lock removal question and fit question
- decoding 1964 F85 Cowl plate
- Hey has anyone had this issue ????
- question on wheel and tire sizes
- Vacuum tanks
- Starting the early cars
- Interior door handle
- 70 Olds Cutlass Steering Wheel nut size
- Wolverine Camshaft
- Vac throttle hold
- Vacuum Diagrams, anyone?
- 3 separate problems - all vacuum related?
- 1970 4-core Harrison radiator questions
- Bucket seat covers 1977 Cutlass
- Rally Pac Gauges
- air cleaner adhesive?
- Interchangeable molding '73 Omega
- Engine oil Brand
- Carb problem?
- 1964-65 Cutlass inner fender
- 1960 Olds Dynamic 88
- Four core radiator
- Correct carpet for a 1977
- Blow-By 394
- help on my 69 olds radio
- Holley carb problem
- Engine temp and oil pressure sending units
- Replacing drivers side door glass
- Dip stick tube
- Intake Manifold on 1972 Cutlass Supreme
- 1971 442 A/C mounting brackets
- 1964 Cutlass Cowl Tag Decoder
- 57 starfire 98 accessory options
- 57 stenciled number on frame?
- KH 2 groove PS pulley w/o holes - mod
- Heat Soak on Starter 1970 Cutlass
- 1968 Bumper Jack Rubber Insulator
- High Torque Starter w/ Hooker Headers - 350
- Fuel cell for '70 442
- 1970 Cutlass Heater Core Replacement
- Learned something today...want more
- Powermaster 9610 Starter for 307/350
- Power steering pump/brackets
- 1987 442 chrome wheels
- Interchangeable Parts?
- 68' 442 Headlight Surrounds
- 68' 442 grille emblem attaching
- 1966 oldsmobile 330 intake manifold bolts
- Pilot bearing
- 69 drive shaft yoke swap
- Car won't turn over
- 67 olds 425 starter
- Brakes
- 61 2dr bubbletop
- Gas guage problems
- 62 Super 88 Driver's Door Locks Itself
- 65 Dynamic 88 Rear Door locks
- Looking for Door Window assembly diagram
- Shift Kit in Toronado
- Windshield washer pump
- Hood Release Broken
- Engine Oil "dipstick"?
- Rear shock absorbers 1958
- Vintage Frame repair
- Window Regulator Roller Question ???????
- 1968 Vin and trim tags
- rear convertible bow
- Best engine break in oil
- 68 442 no/AC heater blower resistor 3 prongs or 4?
- 12 bolt non posi
- Vinyl Top Suppliers
- 1960 steering column question
- Looking for source for Steering Column Sleeve
- Shift knob thread size
- 66 Cutlass/442 Non-Tilt Column Diagram
- 73 and above tilt columns
- Conv top switch
- 55 vent window rebuild question
- Overheating
- 1970 Dash Color
- Welding in floor panels
- Lower Fan Shroud Hardware/Proportioning Valve wire connection
- 68 442 convertible cover boot install
- Tripower foam filters
- 64/65 cutlass trunk lid
- 68' Dash Clock
- Lower control arm interchange question
- smoke out of the crank filter
- Overflow Tank for 1971
- Convertible Inner window fuzzy/felt
- Radio interchange, Who has the truth
- Hood Skin to Frame Spacing
- Interior Doors
- Need 58 98 photos
- Gas tank question
- vin decode?
- inside decklid coating?
- Gas Tank Pressure
- Omega headlight bezel
- Vacuum Advance: Ported Vs. Direct Manifold Part XVIII
- front control arms?
- 70 Back Of The Hood Tooth Color
- vapor Lock?
- Engine harness question on 70 A Body
- Timing specification
- Fan Clutch Question....1967 Toronado
- Q-jet base gasket thickness?
- wider radiator bracket
- Dual gate shifter dust cover spring
- pump
- can't keep car running ( 62 olds )
- Sector Gear Help! for Tilt wheel
- dohc v8
- can am DOHC425
- Broken ignition switch
- 1955 disc brakes
- 1969 specs
- 70 fuel gauge
- Steering Knuckle Arm part #'s: '68 442
- Belt and Vacuum Line diagrams
- 350 carbs
- R-12 valve core source
- help
- How do I defeat steering lock?
- Everytime I have a question I come to this forum haha!
- decal placement 66 delta 88
- H.E.I. or stock
- Dual Gate Shifter cable identification
- 68 442 original carpet style
- Tuning with a vacuum gauge?
- Car engine fire
- 1970 Olds Trim/Rough Hardware inspection form
- Need help decoding body tag
- Olds rocket horn button
- Delta 88 dual exhaust
- Someone please help
- 1964 jetstar 88 lower control arm bushings?!
- 455/TH400 swap
- 1971 Cutlass S oddities
- 65-67 Exhaust Manifolds missing large X & W. Are they factory?
- Radiator question
- Fuel Standpipe Assembly
- mods required for harlan sharp roller rocker?
- serial/ VIN decoding
- Ignition rod 1970 Cutlass
- Muffler Removal Tips
- Toronado Manifolds on a Delta?
- remove oil dipstick tube
- Factory dual exhaust A body clearance question..
- 1966 Cutlass Vert Trim Tag
- J-2 Air Cleaner conversion
- Passenger door won't open from outside
- Function of baffle behing inner fenders of 68 442
- Correct '70 442/W30 fender badge placement
- 1964 cutlass
- Location of Baffle to Filler Plate Seal on 4sp 68 442
- Power steering hoses
- STV update kit
- Is there a Specialty Wheel Storage Decal for 1968 442
- Automatic or 4 speed
- rebuild hood hinges?
- fuel gauge on 1986 Oldsmobile delta 88
- Just about everything you need
- Correct sealant for heater box to firewall install?
- Distributor date code
- The '69-'72 Shifter cable f/s exc. DG...
- 1972 Spoiler Deck Lid Stripe Delete
- Steering Column Question
- 1970 Cutlass Supreme Convertable
- 1970 442 convertible VIN question
- 396021F id
- Cylinder Head ID
- Exhaust manifold removal
- OilClearances/cushing
- Fuel line routing with a twist
- Oil for knee action shocks
- 56 Olds cowl tag decode
- Looking to buy .... but would like opinion
- Putting aftermarket AC in a 67
- 1970 442 w-30 Verification Assistance
- Steering gear pitman shaft seal
- 66-67 core supports
- Fuel tank size
- A proper working carb and choke
- Fuel Pump - any preference?
- 1962 S-88 Brakes: Dual MC Conversion Question
- 68 Cutlass weatherstrip
- Carb Components PN ID cues
- puking gas from breather tube
- 1967 442 CA built body tag decode
- Neutral safety switch? Ignition problem
- AC w/o HDC ?? WTH ? in PN Manual
- more air
- looking for 76 cutlass supreme setcor gear
- Brightest headlights on a 1970 Cutlass?
- Drive shaft stripes
- Testing the sending unit on a '68 Olds 98
- 76 Cutlass Supreme won't start.
- 1968-72 Vista Cruiser/Cutlass wagon tailpipe hanger quetsion
- 52 Olds 98 front spindle size??
- 350 or 455?
- hydromatic- jetaway
- Color Striped Vacuum Hoses On 68 A Bodies - Revisionist History?
- little window type guides?
- GM key cutter
- 71 Cutlass 15" wheels
- Pertronix Ignition Module - Install Questions for a 1962 Super 88
- What's the Small Cylinder on my Ignition Coil
- 7.5 cutlass supreme rear end problems
- PS fluid
- 1953 steering gear "ballnut"
