Blow-By 394
It is hard to get one of these old first generation engines without some blowby. It makes you realize why we have PCV valves and then the emissions controls we have today. I have used Restore ( http://restoreusa.com/ ). and it seemed to help. However, it is not an overhaul in a bottle.
Good luck with additives,but blow by is caused by worn rings and sometimes groves worn in the cylinder walls.Therefore there's usually no easy fix. It will do no harm to try some of the known additives. Larry
