Car won't turn over
Old Aug 9, 2015 | 05:00 PM
Joe Hatton's Avatar
Car won't turn over
I have been restoring my car for 5 years and am ready to start it, but no luck. I remember taking off an alarm system but can't find any cut wires. I took a photo of the switches on the steering column with the wires as installed. There is one spare terminal on the switch closest to the firewall. I have power and the radio, etc all work, just the purple wire to the starter gets no juice when I try to start it.
On a side, or related note, the purple wire loose in the photo is from the horn relay, but not sure where it goes? The horns work and the "buzzer" comes on when door is open. The other photo is an orange and pink wire that I am not sure where it hooks up.
Any ideas? Thanks in advance, Joe
Old Aug 9, 2015 | 05:40 PM
Octania's Avatar
I suggest that for initial start purposes you take command of the ign and start circuits, bypassing all the car's interior wiring. Get that ironed out later.
Hotwire the ign with your own wire/ fancy switch box, and grab that violet wire to the starter and apply 12V to that when you want the starter to work.
If Auto Trans, your Neutral Safety Switch must be working and hooked up. MT cars sometimes have a clutch actuated safety switch.
Old Aug 10, 2015 | 03:07 PM
Joe Hatton's Avatar
Got it - thanks. Any idea on a permanent fix or area to check would be greatly appreciated. It start and ran fine prior to the resto. I am sure I have a missing wire or something - just not sure where.
Old Aug 10, 2015 | 03:26 PM
I'm afraid that the permanent fix requires you to study the wiring diagram in the Chassis Service Manual and start tracing the wires in the starter circuit until you find the problem. The starter circuit isn't particularly complex. Power comes to the ignition switch from the red wire from the horn relay power stud. With the key in the START position, this 12v is applied to the purple wire coming out of the ignition switch. That wire runs to the NSS, and from there to the S terminal of the starter. That's it. If the battery is in good shape and the two battery cables are in good shape and connected properly, and the starter is in good shape, the car will start. You can check for power on the red wire to the ignition switch, the purple wire to the NSS, and the purple wire at the starter.
By the way, what year and model? Is the NSS backdrive linkage properly connected?
Old Aug 10, 2015 | 05:04 PM
jaunty75's Avatar
Car won't turn over
Really? I've never had any trouble getting mine to do it.
It's getting it to turn back that's the problem!
Old Aug 10, 2015 | 05:53 PM
Joe Hatton's Avatar
Will try that tonight. Thank you!!
Old Aug 10, 2015 | 09:18 PM
Joe Hatton's Avatar
Problem solved. Cleaned the dust out of the NSS from the body shop and rotated column while holding the key to get NSS in the right spot. On a side not- forgot that the 18436572 firing order is counter clockwise in an olds. Thanks to oldsmob455 on youtube for making the comment on his video. Thanks for all the advice!!
Old Aug 11, 2015 | 06:05 AM
Glad you found your problem.
Old Aug 11, 2015 | 06:13 AM
...rotated column while holding the key to get NSS in the right spot.
I'm guessing this was the real problem. Has this car been converted from column shift to floor shift? Did the backdrive linkage get lost in the translation?
Old Aug 11, 2015 | 09:27 AM
Octania's Avatar
That is now an anti-theft feature.
If you don't manipulate the column collar it won't start.
CLcutlass
Paint
28
Feb 6, 2020 05:57 PM
stevengerard
Sep 10, 2014 03:17 PM
Kowal
Aug 9, 2014 09:18 AM
dr.chaos
Mar 15, 2011 03:37 PM
miho35o
Nov 7, 2008 08:22 AM
