Starting the early cars
You retard the timing to start, then advance to run, then vary the advance based on load as you drive.
If you do not retard the spark enough, the engine will kick back, and the crank can break your arm.
How do you know its retarded? We're they all set up that bringing the lever literally down would retard it and then up to advance or could it be reversed? How would you know if it were set up wrong? Does the distributer actually turn? And if so would one direction indicate retard or advance? Thanks
You could confirm operation by observing the movement of the points plate inside the distributor.
I do not believe that there was uniformity in the way that the timing levers worked.
costpenn
Apr 6, 2012 04:05 PM
jensenracing77
Oct 25, 2009 05:22 PM
