Conv top switch
Old Jul 12, 2015 | 07:21 AM
Rocketbrian's Avatar
Conv top switch
I was chatting with a buddy yesterday who was having issues with his top on his 71 Supreme. It went up but now it won't go down. He was trying to access the switch through the gas guage, but can't get the harness connector off. Are there any hidden latches to release or are they just a very tight fit and need to be pried from all sides? I'm thinking he will have better access from under the dash after removing the A/C duct. Thanks for any help.
Old Jul 12, 2015 | 01:17 PM
2blu442's Avatar
Brian, I've got a 1971 wagon and the tail gate power window is the same switch as the convert. I would go from under the dash, and yes he'll likely need to remove some AC duct work. I just tried to get a photo of the backside of mine but couldn't get a good angle to work. Using a mirror and flashlight it looks like there may be two 1/4" head screws that hold the plug on. Is there a diagram in the Chassis Service Manual? John
Old Jul 12, 2015 | 05:38 PM
Lady72nRob71's Avatar
I think the connector has to be removed before the white plastic retainer can be unscrewed (wires too close to screw head). You can try it, but pull the battery cable first.
All I know is that it takes a good deal of patience to get it off.
Some details and pictures are seen in this thread:
https://classicoldsmobile.com/forums...html#post58161
Also in that thread is how to take apart the cruise and top switches for contact repair.
66olds98conv
Ninety-Eight
Mar 21, 2013 12:52 PM
Delta88Vert
Aug 12, 2012 11:39 AM
The_German
Aug 28, 2011 08:18 AM
arnyishere
Oct 9, 2009 10:19 AM
