Four core radiator
Old Sep 11, 2015 | 02:54 PM
stanzaschance's Avatar
Cool Four core radiator
Hello,I'm in need of a decent radiator for my 1966 oldsmobile f85.It has 330 engine along with a/c and heat that's why I would like a four core radiator.Thanks.
Old Sep 12, 2015 | 11:39 AM
I had my original 3 row radiator recorded with a high efficiency 4 row at a local radiator shop and it keeps my engine cool during the 110+ Phoenix summers with the AC on.
The core was made by Craig but I don't have the part number now as I'm traveling. If you need it I can post it when I get home, or you can try searching for one of my earlier posts with the info.
Old Sep 12, 2015 | 11:46 AM
therobski's Avatar
I bought this aluminum radiator from Auto Zone part number 433840 $120.00 it drops right in a 67- its for a Suburban-or C-10. Double check but I think 66-67 core supports are the same. Then you need two hose reducers from NAPA 900 and 901, there like 3.00 each. My 455 stays at 150-180 degrees in Texas heat. I'm assuming you have the 2 speed Jet-away trans-you will need to reroute your cooler lines, Mines a M-21 4-speed. If your going original scratch the idea.
Old Sep 13, 2015 | 08:40 AM
Don R.'s Avatar
Check these folks out. Order the high efficiency core, original look and fit with better than aluminum performance.
http://www.usradiator.com/oldsmobile...ator-8135.html
Old Sep 13, 2015 | 05:25 PM
I checked my records and the shop rebuilt my radiator using a Craig 858384 high efficiency core and my original end tanks.
ttg
Mar 30, 2014 03:10 PM
dnmfranco
Feb 7, 2014 09:09 AM
tcarroll
Dec 26, 2012 11:48 AM
60193W30
Nov 4, 2012 05:41 PM
tcarroll
Sep 17, 2012 09:22 AM
