High speed relay
Old Oct 6, 2015 | 04:24 AM
Bfg's Avatar
Bfg
High speed relay
I have 65 Cutlass and the high speed on the heater fan doesn't work. Where is the relay for the high speed located?
Old Oct 6, 2015 | 04:50 AM
'65 doesn't have one. Check the connections and the speed switch.
Old Oct 6, 2015 | 05:10 AM
rocketraider's Avatar
Oldsdruid
My guess is a burned out heater resistor, though I've always thought the resistor coils were bypassed for high speed.
That resistor wiring connector isn't above suspicion either. Notorious for burning out and corroding.
Old Oct 6, 2015 | 07:03 AM
Bfg's Avatar
Bfg
That makes sense cause at first I had no blower but after I cleaned the connections I had low and three but no two and high. I'll take a better look at the connections again. The coils look to be intact. Can they be cleaned somehow? And like you mentioned it could be the switch itself. Can the switch be cleaned?
Old Oct 6, 2015 | 09:17 AM
... I've always thought the resistor coils were bypassed for high speed.
Exactly - low or medium speed problems can be a bad resistor, but high speed cannot be because the current does not go through the resistor.
Old Oct 6, 2015 | 09:18 AM
Oldsdruid
You can use some radio & TV tuner cleaner on the switch, if you can find it. Digital tuning all but wiped out the demand for analog stuff. You may find it as "contact cleaner" at an electronic or industrial supply store. CRC is a well-known brand.
You should be able to find an opening on the blower switch to spray the cleaner into. Then work the switch thru all four positions a few times to dissolve and scrub the corrosion off the contacts inside.
Use a wire brush and the cleaner to clean the resistor plug terminals.
You'll need a continuity tester or ohmmeter to check the resistor coils. With no voltage to it, probe each coil's terminal ends. You should have some resistance on each coil. If you get infinite resistance, that coil is broken somewhere.
Blower motors can be plumb aggravating to get running properly.
Old Oct 6, 2015 | 09:40 AM
Bfg's Avatar
Bfg
Ok thanks for the Info!
Macadoo
Jun 24, 2014 05:36 PM
pcard
May 14, 2014 01:21 PM
smcurro
Paint
Jan 29, 2012 02:31 PM
craftsmen22
Dec 29, 2011 10:10 AM
clarablue
Apr 25, 2007 04:15 PM
