inside decklid coating?
What is the best thing to coat the inside of a 69 decklid with? I was going to pour rust incapsulator inside and rotate it around. Or is there something I can buy that is for doing this? Thanks in advance
ng
I totally agree with coating the inside of the decklid, especially along the seams. Seeing what I paid for a rust free decklid and hood for my 66 Cutlass, with the money and man hours I've put into it so far I'll do whatever it takes to help preserve it. I see it as money well spent and protecting my investment.
Thanks, Ron
My car is always stored inside under a car cover but not in climate controlled perfection and it's lasting just fine.
I have used POR 15 numerous times inside trunk lids as they habitually rust where the water settles in the top & bottom seams. I pour into a cup, pour into the framing & rotate the lid around being sure paint runs out of seams & drain holes. After it dries then use a rust inhibiting product (wax from nearly any body product mfg, Fluid Film, etc. aerosol w/straw). Make sure you don't block the draIn holes & have multiple layers of paper on floor to catch the runoff.
In Texas you hardly have an issue with rustout from condensation. I still have the OEM deck lid my car came from and there's not enough light surface rust on the inside of the deck lid to consider as even being rust and that's after it was painted back in 86. It never had any additives swirled around inside the deck lid either.
My 1970 Supreme deck lid rusted out so badly in 1982 that I replaced it with a new one because I couldn't find a non-rusted through one at any of the local salvage yards. I poured Rustoleum paint in the inside of the new one and rotated it around until paint came out all the corners; that replacement was rusting through by 1998.
I had to replace the lid on the '71 when I got it in 1990 due to the entire lower edge being rusted through (it had lived its life up til then in the Houston area).
I guess my car has been extremely lucky to live here in a cold climate with relatively little humidity. I'll bow out of this because I really don't have anything to offer. Good luck with the deck lid sealing.
Too bad you can't take it to a car factory or paint shop and have it entirely dipped in the liquid primer they use for protection nowadays.
Eastwood does sell a rust inhibitor paint that has a special nozzle for spraying inside frames. I'm wondering if you can use through the holes in the deck lid frame. I also use a clear coat rust inhibitor for inside my doors etc.
wmachine
March 13th, 2009 06:03 PM
