View Full Version : General Questions
Pages :
4]
16
17
18
19
20
- 442 tail light heat reflectors
- HD cooling and radiator type?
- Curious: Why? Fluid Filled Fuel Pressure Gauge
- Camshaft - Lift, Head Flow, Duration, Horsepower
- 1971 Cutlass S Coupe - Post Car - Roof Rail Weather Stripping
- 1970 Deluxe Steering Wheel Wiring
- will chevelle door handles work on a 72 cutlass
- Proper undercoating
- coil pack for 91 delta 88 has a ding in the ceramic coating on the bottom
- Factory Tape Deck
- 79 cutlass project
- Modern cam grind performance
- 57-63 Deluxe wheelcover clips
- 455 in 66 cutlass interference
- Window regulator parts
- Ignition Barrel Stiff
- Hood Adj. @ the nose
- Fan shroud dimensions
- Fastening hood chrome question
- Drain Cover, Rocker Panel, 65 olds 442
- Gauge upgrade
- Clock lens
- 64-65 cutlass inner fenders
- VIN rivets
- Dvcs 101
- '68 4-4-2 (A Body) Sway Bar Link Dimension?
- 1984 cutlass supreme small coolant leak
- Tailgates
- phosphate plating hood hinges
- 350 to 425
- CCC Qjet Rebuild Advice
- Quadrajet question
- Oil pressure warning light diagnosis
- Another 350 to 455 swap
- I need help decoding my tag
- 1968 Under Bumper W30/31 Scoops Install Question
- 69 olds 442 b85 reveal moldings
- Ride height
- Quadrajet Diagram
- 68 spark plug brackets. I need some help on this one
- Heater box/ heater core 64 Starfire
- 67 442 Tilt Horn part needed
- 64-66 A body tilt column
- Steering column issue, 1963
- 7040256 Carburetor question
- Option code AV3??🤔🤔
- Special paint program
- Quadrajet replacement
- 1970 Air Deflector for 442
- 66 post coup
- Seeking advice on rally gauges and temperature readings
- Batteries for R-59 Battery Topper?
- 71 Power bench seat rear brackets
- 1959 394 engine rocker setting
- 63 Starfire Saginaw PS reservoir removal
- 83 H/O Positive battery Cable question
- Convertible top switch rebuild
- Door Locks - No Code Stamping?
- now i'm screwed. broken bolts
- Where would I find the radiator code?🤔🤔🤔
- Speedo cable
- fast info please!!! color code 75
- 70 442 grill assembly
- Column Shift Lever With Tilt
- Temp Sender unit confirmation.
- 442 air cleaner
- Cutlass 3/4 side window removal
- Dark Siders-need some help with 63 Starfire front engine mount
- Heat stove pi[pes
- Turbo 400 Trans Lever
- Flowmaster Tailpipe installation problems
- 1969 Cutlass Power Steering Hose
- Repop W-455 manifold.
- Replacing rear stabilizer bar, '70 Cutlass
- Info please 70 convert top motor
- 6-Way Power Seat Service/Repair Help Please
- Trunk Spoiler Debate
- Silver Paint Match for 1972 442 Grilles
- What a difficult year this has been!
- !968 442 firewall holes
- What did heater delete entail?
- 1967 442 with air heater control valve
- Help identifying wire, 70 cutlass convert
- Non-A/C Lower Vent Plenum
- Carb Identification
- Fuel pump I.D.
- Oil filters 2020
- 68 Cutlass 350 2bbl automatic with Ac Vacuum line diagram?
- Brake Help Needed....PLEASE
- 371 head gasket replace due to age
- QUESTION window regulator interchange
- Need some help with Rallye Gauge
- Messed up steering column
- 371 Engine Colour
- 90s 00s alloy wheels with clearcoat
- 1959 oldsmobile factory a/c compressor color
- 1970 Dualgate Neutral Safety Switch
- Assistance with steering wheel lock mechanism.
- What do you guys know about this stuff?
- Hub cap ID help please
- National Carburetor
- need help/info please power windows
- Reproduction Stainless Trim
- Float Height spec on a 63 Dynamic with 2GC
- 455 dowel pin
- Starters
- Distributors
- 70 442 vin decode 4th and 5th digits
- futuramic DELUXE?
- Part I.D.
- overtorque
- molding I.D.
- kick panel I.D.
- No heat or blower fan
- Upper ball joint castle nut size for a 1964 98 olds please
- Opinions of these cam specs
- Can’t keep coolant in the radiator
- 4 Bolt Master Cylinder? - 1967 Olds Cutlass
- Thread Sealant for Carb Fittings?
- NEED HELP identify this part
- Exhaust manifold Assembly
- VIN number for 1957 Oldsmobile
- Yearly maintenance
- Vacume hose def/heater diogram 71 442 with AC
- Correct part and part number for radiator fan
- Power Seat Problems
- Top ring land CC
- Distributer drive gear roll pin
- Starter is shot
- OK, I'm stumped
- Engine bay light harness location help
- 61 Starfire 4GC Part Number
- 1971 Cutlass 350 4 barrel fuel injection conversion advice
- 61-64 Starfire A/C availablility-stallation
- correct rear end and code
- Heater Box Internal Flap Seals Replace
- Help! My carb trickles Gas at idle???
- Outer Door Weatherstrip Dew Sweep Interchangeable???
- Interchangeable Bumper?
- Rocker Arms
- 442 Rear bumper exhaust cut outs
- Convertible top
- Blown head gasket?
- 134A Refrigerant
- Convertible boot
- A/C Help Needed
- Help with 66 throttle linkage
- 371 extra capacity oil pan on ebay
- Dealer installed antifreeze decal location
- Steering wheel off center?
- Manually open top on 71 cutlass
- Fuse Box Connection for Power Seat Feed Wire?
- Any issues with Phoenix Graphics customer service?
- Please help me buying tools!
- 62 Starfire A/C and heater vacumm lines
- 1971 CUTLASS AC Compressor to lines "O" rings
- 71 Neutral switch
- Electronic ignition tuneup
- Will some1 decode this please
- 1964 olds cutlass 330 4v
- 442's registered in Ontario Canada
- coolant change
- cutlass 66 radiator coolant level
- Molding identification
- PC tag 4 row Manual radiator
- Rebuild/update radio question
- Vacuum trunk opener potential malfunctions
- 4GC differences / interchangeability
- 4-Way Power Seat Adjuster '70 Cutlass
- Any1 have pics of oai latches/bumper stops
- Coil spring tags
- Again need H.E.L.P. On frame rear rails switch ????
- Need H.E.L.P.
- Info on shifter ball I found
- Intake Manifold ID #'s
- 70 442 Wheel Recommendation
- Vintage Mallory Points
- '70 Cutlass headlight surrounds - drop the bumper?
- Front bumper have to come off to remove the horns?
- Best way to rebuild my 1971 350 Rocket
- Thornton header fit really tight - need opinions
- 1970 OAI hood painting - tooth installed first?
- Heater switch knob
- 72 cutlass ignition switch
- Hood question
- Informational Bulletains
- 1980 442
- What do 170 Series Qjet primary rod letters mean?
- Central PA Shop Recommendation
- Assembly manual quality??
- 1955 88 2d HT
- 1955 88 2d HT
- Terminal wiring Rallye Gauge
- Glove box hinge/hardware?
- Air Conditioner
- Internal Engine Rust: Clean and Flush Products?
- convertable top rear window
- 1966 330cui exhaust manifold
- Power door lock/window wiring layout?
- Parking Lamp Replacement
- What cam are you using?
- Looking for Tool Advice - Leak Down Tester
- Exhaust dead end
- 72 Cutlass fuel tank
- 70 brake booster/ master
- Mechanical Furl Pump Help
- 70 Cutlass Sport Bullet Mirror Adjusters
- 66 v8 distributor
- 72 Rear Power Window
- Correctly restored Wiper Motor
- What is this?
- Vacuum Advance Control Specs
- Quadrajet ID number for 1969 442
- 70 - 98 Power Seat Problem
- Name that bell!
- Lower Rad Hose
- Knocking under braking and acceleration
- Flywheels
- Distributors
- UHV Application Guide?
- Fan Identification
- Which Compression/Leak Down Tester?
- Info pls, weight of bare 455 and shipping info
- 68 442 turnpike cruiser questions
- Rear Power Window - 72 Convertible
- Lock Hood
- Factory Vacume gauge
- flexplate
- Please help - Decode 71 Olds Cutlass Cowl Tag
- It's been a tough month for friends and relatives
- Info on 68 442's please
- Air Cleaner Identification
- Air Cleaner #3
- Another Air Cleaner
- Air Cleaners Ahoy!
- fresh 455 build tune up help needed
- Need Help Identifying Air Cleaners
- Carb sizing vs head flow #s
- radiator shroud question heavy duty
- need some help
- 1967 Phoenix Graphics Stripe kit
- What is this wheel from?
- Oil pressure warning light.
- 69 442 Bumper question
- 1965 tail panel
- Need vacum hose diagram 1970 olds 442
- Fuel Pump question: 69 400ci
- Need Help Identifying Part on 1968 Cutlass 350
- Is The AC Muffler Really Needed??
