Rear Power Window - 72 Convertible
How difficult is it to replace the rear drivers-side power window motor on a 1972 Cutlass Convertible?
If the window is stuck in the "down" position, can it be manually lifted to the "up" position until a replacement motor is installed?
Any good places that sell the window motors?
I found a motor on OPGI and they want $90.00 for it.
AutoZone and O'Reilly's no longer carries that motor. I also noticed that some places that sell the motor DO NOT include the internal gears in the motor. I assume those must then be swapped out from the factory gears?
ddx77
January 25th, 2012 11:24 AM
