Rear Power Window - 72 Convertible
Old June 3rd, 2020, 08:39 AM
pettrix's Avatar
How difficult is it to replace the rear drivers-side power window motor on a 1972 Cutlass Convertible?
If the window is stuck in the "down" position, can it be manually lifted to the "up" position until a replacement motor is installed?
Any good places that sell the window motors?
pettrix is offline
Old June 3rd, 2020, 09:42 AM
You have to remove the back seat to remove the side panel. The motor uses a worm gear drive that is almost impossible to manually backdrive to pull the glass up.
joe_padavano is online now
Old June 3rd, 2020, 10:54 AM
pettrix's Avatar
I found a motor on OPGI and they want $90.00 for it.
AutoZone and O'Reilly's no longer carries that motor. I also noticed that some places that sell the motor DO NOT include the internal gears in the motor. I assume those must then be swapped out from the factory gears?
pettrix is offline
timothypaul
April 25th, 2020 12:47 PM
Convertcrazed
March 28th, 2016 06:32 PM
Delta88Royale
January 16th, 2014 12:30 AM
RickH
June 23rd, 2012 07:38 AM
ddx77
January 25th, 2012 11:24 AM
Quick Reply: Rear Power Window - 72 Convertible
