79 cutlass project
79 cutlass project
Hey guys I'm new to the forum I have a 79 cutlass with a 260 in it yeah I know but the car only has 49k on it no rust and I'm from Pa so that is not common for a 40 year old car anyway I bought a 77 with a 350 #6 heads and a better transmission and if the rear end fits my question is will the rear end from the 77 fit it also has a Elderbrock 1405 carb sitting on the stock intake I read a few threads on the rear end and with some modifications it can fit not sure and should I ditch the 1405 and go with a Qjet thanks for reading and any advice you can provide
The 7.5 rear will live behind a reasonably stout 350.
If you rebuild the reset end, use a shim kit to set pinion preload, instead of the usual crush sleeve. One of the durability issues with the 7.5 is the pinion bearings loosening up when the crush sleeve continues to crush under heavy loads.
Install a rearend cover that have the cap bolts to stiffen the carrier bearing caps. The factory cap casting is pretty flimsy, the bearing caps move around and causes additional wear.
I wouldn’t put any more money in a 7.5 rear for parts (other than the rebuild/gearset). By the time you spend the money for better axles and carrier, you could have rebuilt a stronger 8.5.
Keep a Q-Jet on the engine. Build a QUALITY rebuild kit from a Q-Jet specialist. A 30 Advance Auto rebuild kit isn’t enough. Get the needed parts to recalibrate the Q-Jet for your application.
I really like the Olds G body cars. I have owned at least one of every year olds cutlass/442 from 68-88. Obviously my favorite Olds is my current 69, but the G body cars are by far more comfortable to drive.
Welcome, and good luck
thanks I was planning on upgrading the axles and doing a Yukon posi 3:23 or 3:42 gears not sure what will be best
Didn’t someone make upper control arms to fit a A body 8.5 rear into a G body? If I remember correctly, the lower control arm mounts are in the right location, the upper mounts are at a different angle.
Found the answer here.
https://www.umiperformance.com/home/...-control-arms/
Looks like the A body tear ends are 3 inches wider than a G body, so it’s probably going to take wheels with different backspacing to fit.
Personally, I’d roll the dice with the 7.5. If/when it breaks, then do the swap. I’m willing to bet the 7.5 will live a long life behind a mild 350.
More to the point, have you priced desirable 68-72 A-body rear axles lately? That's not really a savings as compared to the G-body 8.5, especially once you get past the special UCAs and wheels.
MY76GUTLASS
Jan 22, 2011 07:36 PM
