Column Shift Lever With Tilt
Old Oct 25, 2020 | 06:40 PM
Toms cutlass's Avatar
Looking to replace the "pad" and "sleeve" on the A/T column shift lever with tilt wheel from a '71 to the correct fluted sleeve and pad for '70 Supreme. I have new OE pad and sleeve correct for '70. How does the "insert" (see diagram) come off the shift lever? Is it press fit or threaded? Can I re-use the insert? The sleeve for '70 is about 3/8" shorter than the sleeve for '71.
Thanks in advance.
File Type: docx
Old Oct 26, 2020 | 04:31 PM
oldolds88's Avatar
any ive dealt with are light press fit,on splines
Toms cutlass
Mar 2, 2018 03:16 PM
hvysupreme
Feb 18, 2017 12:40 PM
gratsoy
Vista Cruiser & Wagons
Jul 22, 2016 05:49 PM
ELY442
May 10, 2016 04:48 PM
Rocketbrian
Oct 2, 2013 10:18 AM
