64-66 A body tilt column
Old Nov 28, 2020 | 05:46 AM
dbater's Avatar
Hello,
Does anyone have information on rebuilding one of these vintage tilt steering columns? I have purchased one to install in my 65 442 but the tilt area has excessive play. Any and all advice is appreciated.
Old Nov 28, 2020 | 07:47 AM
rocketraider's Avatar
Oldsdruid
Never messed with that year but you may be able to fix it yourself. Later columns have four screws buried below the turn signal actuator that sometimes work loose. If you can see down in there, a long screwdriver can sometimes get in there to tighten them up and eliminate the looseness.
Old Nov 28, 2020 | 11:13 AM
dbater's Avatar
Thanks,
yes I guess I'll have to get it apart and go from there.
Old Nov 28, 2020 | 11:24 AM
Loaded68W34's Avatar
The hardest thing to deal with in these columns are the springs that pull the steering wheel up when you release the tilt lever. Unlike later 69-72 columns that have a large coil spring at the bottom which pushes up, the earlier columns have two coil springs at the top which pull on the column. I have found the best way to release them is to pry them off of the attaching "hooks" with a small pick.
Old Nov 28, 2020 | 12:14 PM
dbater's Avatar
Thanks for the advice!
Old Nov 28, 2020 | 12:16 PM
dbater's Avatar
Old Nov 28, 2020 | 07:58 PM
edzolz's Avatar
There is a company in Athens Texas that builds exact replacement tilt columns for A bodies. I do not have a name but you might try a google search. You migh be able to buy parts from them.
Old Dec 12, 2020 | 06:08 AM
dbater's Avatar
Thank you, I will research.
Old Jan 9, 2021 | 09:29 AM
forstatd's Avatar
Chuck Schuster, Parts Finders in Jackson, Wisconsin, is rebuilding the tilt column in my 66' 442 as we speak. Great guy... has rebuilt 1000's of steering columns & knows his stuff!!
Old Jan 9, 2021 | 09:44 AM
dbater's Avatar
Have you been in touch with him recently? I have tried contacting him but have not heard back.
Old Jan 9, 2021 | 09:46 AM
forstatd's Avatar
Yep, he is working on my column as we speak. Talked to him yesterday. Here is his e-mail address... musclecarman1969@hotmail.com
midnightleadfoot
Jun 9, 2017 03:59 AM
oldscs
May 26, 2015 05:21 AM
charlierogers
May 1, 2011 03:21 PM
1968Cutlassfallbrook
Apr 30, 2011 02:24 PM
Kidcutty
Jan 19, 2010 06:35 AM
