70 442 Wheel Recommendation
A friend is looking for recommendations on Coker SS1 (all chrome) wheel size for 70 442:
14" x 6" 4" backspace or-
14" x 7" 4.375" backspace or
15" x 7" 4.375" backspace
thanks,
Dave
thanks,
Dave
14" tires are becoming scarce these days and that size wheel may prohibit a disc brake upgrade if one is contemplated in the future
another option is 15x8 wheels (4.5" BS), which would facilitate a wider tire width range - for example, I run 15x8 Torq Thrusts with 245-60-R15 BFG Radial T/A's all around on my '72- reasonably wide footprint and no clearance issues.
the only potential downside to a size upgrade is the likely need for a speedometer gear set swap to correct for the tire size change. but in my opinion worth it for the increase in affordable tire availability.
While that is an option, 15x8 wheels are are not mandatory for that. I run 245-60-15s on factory 15x7 SSIII wheels, and in the past used 245-60-14s on the original 14x7 SSII wheels.
