14" wheel question
14" wheel question
Will a 14x7 wheel with 3" backspace and 205/70 tire work up front on a 78 cutlass?
I currently have 15" wheel with 2"backspace and it hits the back side of the inner wheel well when cut hard left or right...
Car has not bern lowered.. I have a good 2"+ between the top of the tire and the bottom of the fender lip.
I think it's just the backspacing, pushing the wheell too far out, changing the turning radius of the wheel.
Like i said, had no issues with the factory sslI wheels.
I found a set of the hurst 15" rallys i may pick up an try. If a 15" factory wheel hits, then something else is up..
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
